WHO IS RUNNING 572-13 HEADS ? *DELETED*
#1450203
06/09/13 10:54 PM
06/09/13 10:54 PM
Posts: 469 Tennessee
steeldust
Tennessee
With 440-1s on my 572 at 3,200 lbs the best ET 5.63 at mph 129 . Is 572-13 or what head ?
Re: WHO IS RUNNING 572-13 HEADS ?
[Re: steeldust]
#1450213
06/10/13 09:18 AM
06/10/13 09:18 AM
Posts: 10,021 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The 572 head is built off the same castings as the 440-1, just machined at a different angle to get 13 degree valve angle instead of the stock 15 degrees, plus the valves are moved a touch in order to get the 2.35 intake in there. I haven't seen enough gain from others on the board, or elsewhere to justify the $$ for the power you will gain. From what I have seen the improvement would be somewhere around 50 to 100 hp AT BEST. The ports aren't big enough to support any more than that. I have gone 5.56 at 124 on motor at 3,000 lbs on methanol with fully ported 440-1 heads, and Cudabin has gone that fast or faster also. If I recall your heads aren't ported fully, correct? There are a number of things you could do to your current combo to increase power, but the cost is high at this level, as I am sure you know.
[Re: gregsdart]
#1450214
06/10/13 11:38 AM
06/10/13 11:38 AM
Posts: 903 Saskatchewan, Canada
cudabin
I have run 5.41 at 128.25mph with a 1.18 60 foot at 2,600 feet DA at 2,800 #'s... MCH 345cc CNC ported -1's with 557 cubic inch N.A. If you are going to spray it, perhaps just work on the tune up, as the 572-13 will not be that big a step up IMO... I am also using 10.5W but wish i had gone bigger. Cheers, Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
