Re: Challenger flip top gas cap question...
[Re: 318 Stroker]
#1450063
06/09/13 11:18 PM
06/09/13 11:18 PM
Posts: 623 Smack dab in the middle of Ill...
JamaicaBlue
There is no seal. The trim ring lays directly on to the 1/4 panel sheet metal. Do you have a repro 1/4?
If so, sounds like the gas cap opening on the 1/4 may not be shaped properly. The repro 1/4's are notorious for that.
The car has the original quarters and it is a NOS gas cap. Looks like I will take it back off and see what's going on.
[Re: JamaicaBlue]
#1450064
06/09/13 11:27 PM
06/09/13 11:27 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Is the trim ring a repop or original? I got a little play in mine and the trim piece was the only non original part.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: MLR426]
#1450067
06/12/13 07:48 PM
06/12/13 07:48 PM
JamaicaBlue
Eric,
Are putting the challenger back together ? How far along are you ?
MLR426
Hey Martin,
It's painted and parts are going back on it. The last major hurdle is I need a good machine shop to finish the motor. I actually need to talk to you about that as I need a recommendation.
[Re: JamaicaBlue]
#1450068
06/13/13 12:09 PM
06/13/13 12:09 PM
Posts: 4,799 ILL
MLR426
ILL
Eric,
MLR426
Hey Martin,
I hope that would be my shop LOL
MLR426
