Roller rockers for the long term investment #1449680
06/09/13 04:14 AM
06/09/13 04:14 AM
Tacoma, Washington USA
Adam71Charger Offline OP
I've read a lot of posts on this forum and others about roller rockers. I've also talked to my machine shop and hughes, harland sharp and mancini. My budget is about $800. My lift should stay at .600 or under. The car will be wide open throttle as much as possible but will be a street driven car. Im looking for the best, most durable, longest lasting rockers in my price range.
From what Ive heard and read, Im leaning towards the hughes aluminum and Im interested to know if the cryo freezing is just a gimmick or if it's all they say it is. I almost went with the comp ultra pro magnum steel rockers but I read on their site they are needle bearing type and Im shy to that type. My other option was the crane ductile aluminum, but I read the new ones are not built as well as the old style. Then, there is the Mancini labeled harland sharps, they are the best price out of all of these, but havent heard from anyone who's used them. Am I missing any? I have no experience with any of these setups, and havent seen any recent threads on them... anything new or changed with any of these rockers that I haven't read about already?
Re: Roller rockers for the long term investment [Re: Adam71Charger] #1449681
06/09/13 04:26 AM
06/09/13 04:26 AM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
Mancini racing has a kit for $480 that is made by Harland Sharp for Mancini. The kit comes with the mounting hardware too.
Re: Roller rockers for the long term investment [Re: Jjs72D] #1449682
06/09/13 02:37 PM
06/09/13 02:37 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
I got the Mancini set-up for my big block build. Haven't used them yet but they look nice. It's a complete set-up too. I threw down for the billet holdowns too.
And then there's the American made rockers by Dove..............
http://www.4secondsflat.com/Dove%20Rocker%20Arms.htm
Re: Roller rockers for the long term investment [Re: Dean_Kuzluzski] #1449683
06/09/13 06:20 PM
06/09/13 06:20 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Personally I would never run a rocker that wasn't either bronze bushed or roller bearing. I don't like running aluminum on a steel shaft - seen too many cases of galling. I don't know what your concern would be with rollers bearings. As for cryo treatment ... it works. Whether its needed or worth the expense is entirely personal.
Re: Roller rockers for the long term investment [Re: Stanton] #1449684
06/09/13 06:44 PM
06/09/13 06:44 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have been using these Hughes for over 2 years in my street car. They are still holding up very good. Ron
Re: Roller rockers for the long term investment [Re: Stanton] #1449685
06/09/13 06:58 PM
06/09/13 06:58 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
If you go with an alum body rocker bronze bushed is the best , get banana groove shafts also.
Re: Roller rockers for the long term investment [Re: Adam71Charger] #1449686
06/09/13 06:59 PM
06/09/13 06:59 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
After the 'customer service' I observed from Hughes several years ago, they wouldn't get a dime from me...
HS...
Re: Roller rockers for the long term investment [Re: Adam71Charger] #1449687
06/09/13 08:05 PM
06/09/13 08:05 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
nothing beats stainless... I have run the same crower enduros on a gm engine for 10 years @ 1:65 and 1:7 ratios with no issues ever .7500 rpm oval track punishment at that. bent plenty of valves but never had a rocker failure.
Re: Roller rockers for the long term investment [Re: ek3] #1449688
06/09/13 10:36 PM
06/09/13 10:36 PM
IN
ahy Offline
ahy  Offline
IN
The Comp cast alloy steel "pro magnum" rockers may be just right for your application. Durable and work well as shipped up to about .6" lift. Higher lifts and pressures benefit from a bushing. I'm running a set on a 496 with .55 lift and no problems.
Re: Roller rockers for the long term investment [Re: RSNOMO] #1449689
06/09/13 11:16 PM
06/09/13 11:16 PM
HS...
They wernt very friendly w/me when I called, and seemed pretty annoyed when I asked some technical question about their products. But I've never heard a bad thing about their rockers
Re: Roller rockers for the long term investment [Re: Stanton] #1449690
06/09/13 11:23 PM
06/09/13 11:23 PM
My concern with roller bearings is longevity. It seems like most of the forces on the rocker arm would be concentrated on only some of the bearings and would wear them faster than the others. I was very interested in getting steel or iron rockers and getting them bushed, but I've only read about 1 place that does it, RAS, and I have no idea if they still do it or if its even the same company or owner
Re: Roller rockers for the long term investment [Re: ahy] #1449691
06/09/13 11:25 PM
06/09/13 11:25 PM
See I thought these were solid rockers that could be bushed, but they are actually needle bearing rockers
Re: Roller rockers for the long term investment [Re: Adam71Charger] #1449692
06/09/13 11:35 PM
06/09/13 11:35 PM
E
ek3 Offline
ek3  Offline
E
the neddle bearing rockers will never wear out . they will carry any load "you" plan to put on them. get a set like the crower enduro's in STAINLESS STEEL and never buy another set.
Re: Roller rockers for the long term investment [Re: Adam71Charger] #1449693
06/09/13 11:35 PM
06/09/13 11:35 PM
San Angelo, Texas, U.S.A.
1968RR Offline
1968RR  Offline
I was planning on buying Comp's Pro Magnum rockers a few years ago, but decided against them because (if I remember correctly) they're bushed and DON'T have needle bearings. I could be wrong, though...
I ended up going with Harland Sharps. The guys on the race board swear by them and I haven't had any problems with them so far. But I would be sure to make sure clean and inspect any new rockers you buy for shavings (but especially the Harland Sharps).
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Roller rockers for the long term investment [Re: ek3] #1449694
06/09/13 11:58 PM
06/09/13 11:58 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
This advice won't help.
He's looking for shaft rockers so he must have a SB or BB. The only rockers Crower makes for Mopars are for the stud mount V8 Magnum and V10.
Re: Roller rockers for the long term investment [Re: Adam71Charger] #1449695
06/10/13 12:59 AM
06/10/13 12:59 AM
IN
ahy Offline
ahy  Offline
IN
Comp pro magnum are plain bearing rockers. No roller bearings on the shaft but roller tip. Geometry "over the tip" on my BB was excellent. there are no fatigue concerns with extended use as with aluminum rockers . The only drawback is a tendency to gall the shafts with high lifts and spring pressures. With lift under .6" shouldn't be a problem.
Re: Roller rockers for the long term investment [Re: Adam71Charger] #1449696
06/10/13 03:42 AM
06/10/13 03:42 AM
E. Okla line
m88mark Offline
m88mark  Offline
E. Okla line
I think RAS is Rocker Arms Unlimited now.
Re: Roller rockers for the long term investment [Re: m88mark] #1449697
06/10/13 12:28 PM
06/10/13 12:28 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
I have 2 sets of Hughes Roller rockers. 1.5's on my hot street 318 for 2 years now, 4000 miles. No issues.
1.6's on my 408. They are a very good rocker. Hughes customer service has always been good to me...
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: Roller rockers for the long term investment [Re: mopardude318] #1449698
06/10/13 02:22 PM
06/10/13 02:22 PM
dogdays Offline
dogdays  Offline
One of the lucky ones!
If the rocker has a decent lubricant supply, the bushed rocker has fewer moving parts, hence, fewer chances to break. Look at what Isky is doing with its roller lifters.
Needle bearings are so last century!
Although, with that being said, a decently specified and lubricated needle bearing or roller bearing will last a very very long time.
R.
Re: Roller rockers for the long term investment [Re: dogdays] #1449699
06/10/13 02:25 PM
06/10/13 02:25 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Trouble with the needle bearing whether on the tip or the felcrum is that the load is only on one side and they rock back and forth. The needles seldom if ever rotate to a different position on the shaft.
