Chassis Help: Solved for now!
#1449609
06/09/13 12:27 AM
06/09/13 12:27 AM
Posts: 577 Arkansas
Adrielp
Arkansas
So what is everyone doing to help settle the car after wheelstands? We have our car going straight but are getting aggressive and now the car is getting loose when it lands. We want to get our 60ft down but need to better control the car as it lands from wheel stands.
3200lb ladder bar car Single adjustable rear coil overs / 90/10 front shocks Stock front suspension components 650hp engine / 727 trans w/transbrake / 32 slicks 3000 launch rpm
Thanks for the help!
Adriel Paradise Substation Design Engineer III
Re: Chassis Help
[Re: Adrielp]
#1449610
06/09/13 01:03 AM
06/09/13 01:03 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Number 1 thing is to check the toe curve.. you are probably going toe out... that can cause the car to dart to the side pretty easy
Re: Chassis Help
[Re: MR_P_BODY]
#1449611
06/09/13 06:33 AM
06/09/13 06:33 AM
Posts: 872 NJ
SSDAcuda
NJ
When you say "getting loose" are you referring to steering or rear tires unloading? A good set of front double adjustable shocks set tight on the compression side helps settle the car.
SS/DA 1924
Re: Chassis Help
[Re: SSDAcuda]
#1449614
06/09/13 11:21 AM
06/09/13 11:21 AM
Posts: 577 Arkansas
Adrielp
Arkansas
I can testify to that after getting the bumpsteer fixed on mine, the problem went away.
Its seems to do a little of both honestly. When watching the car from the rear, it lands and wants to move around. The bigger the wheelstand, the more it wants to move around after landing. As far as the toe, we haven't looked at it in a while but it was set to have a slight toe in although I'm not sure how much the stagger was that we set.
I know there are a lot of ways to skin a cat to fix this situation, just trying to decide on the most efficient approach(cost, benefit, and functionality). Our thoughts right now are, stiffer rear springs, upgrading the front shocks(their ancient), lowering the rear to lower CG, and possibly some taller tires.
I forgot to mention we put a dent in our pan last night. When I say this car was wanting to get after it, it really wanted to get after it. We started out running a 60ft: 1.41 6.44 @ 107 w/manageable wheelstand, made the ladder bar more aggressive 1/4 turns both sides, 60ft: 1.38 6.38 @ 107.86 w/another manageable wheelstand. Went more aggressive, 60ft: 1.36 (getting out of it)w/wheelstand was too high and unsettled to car upon landing. Left it alone but wend up two clicks on the shock to account for the wheelstand, ran again and low a behold the thing went even higher hitting the pan this time and my dad was out of throttle even earlier. Whats amazing is the weather really didn't change much from the first to last runs. 2100ft Density altitude to 1700ft Density altitude on the last past. Only 7 degree change in temperature although the track temperature changed quite a bit. Regardless, we really need to car to react better coming off those wheelstands. Super Stock cars have no issues, we don't want any either.
Re: Chassis Help
[Re: Adrielp]
#1449615
06/09/13 11:45 AM
06/09/13 11:45 AM
MR_P_BODY
Old junk front shocks arent helping your cause... start lifting the front weight sooner to help reduce the wheel stand... if you allow the motion then you allow it to have momentum... you dont want the vertical momentum ... so if you can start picking up the weight sooner(with the shocks being tight) it should help.. if need be strap the front end(limiters)... also on the rears.. as you seen if you tighten the rear shocks on a good track it only goes higher... loosen the rears and allow the rear of the car to lift more to get the rear up so the CG has to go higher.. then the front has to go higher to get over the CG... just dont let the rear shocks top out... put your ladder bars in the lowest front hole... you may need to ad more holes down lower(if the cross bar is set in too high you might not have enough holes)
Re: Chassis Help
[Re: MR_P_BODY]
#1449616
06/09/13 12:32 PM
06/09/13 12:32 PM
Posts: 872 NJ
SSDAcuda
NJ
Good advice from Mr P! Limiting the front end travel will also help with the bump steer issue.
SS/DA 1924
Re: Chassis Help
[Re: gregsdart]
#1449623
06/10/13 04:58 PM
06/10/13 04:58 PM
Posts: 577 Arkansas
Adrielp
Arkansas
We've decided to do a few things to help control the car better. We plan to check the bump steer, remove some the suspension travel, and lower the car in the rear for little lower CG. We plan to invest in some shocks later this year. Still don't know if we will get Double or Single Adjustable just yet, we would like to upgrade the rocker arms as well and getting both will nip at the budget a lil bit. Regardless, these few things should help the car quite a bit.
Looks like wheelie bars maybe in our future too as a precautionary measure to prevent excessive wheel stands from happening keep the oil pan off the track.
Re: Chassis Help
[Re: Adrielp]
#1449624
06/10/13 05:14 PM
06/10/13 05:14 PM
MR_P_BODY
If you lower the rear of the car your problems will get worse till you can control the front lift(limiters) or better shocks... with the back lower it will be easier to get the weight up over the CG
Re: Chassis Help
[Re: Adrielp]
#1449625
06/10/13 05:16 PM
06/10/13 05:16 PM
Posts: 43,215 Bend,OR USA
Cab_Burge
Looks like wheelie bars maybe in our future too as a precautionary measure to prevent excessive wheel stands from happening keep the oil pan off the track. [/quote ]Wheelie bars are usually bandaid, fix the problem
Re: Chassis Help
[Re: Cab_Burge]
#1449626
06/10/13 11:47 PM
06/10/13 11:47 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
If you are a bracket racer, and run a three speed, your one/two shift is probably close to if not during the landing from a larger wheelstand. This not only affects the way the car tracks (moves around,etc) but the shift timing is affected because you are also busy worrying about the direction the car is going to go when it hits, etc. So taming the wheelstand, eliminating deflection in the front suspension to make it track straight, will go a long way to making you more consistent. A properly prepped front suspension,wheelievbars, and possibly double adjustable shocks will be a big asset.
Re: Chassis Help
[Re: Adrielp]
#1449628
06/11/13 08:55 PM
06/11/13 08:55 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I can understand and appreciate budget. The cheapest thing I can recommend is what has already been recommended. Only problem is the guys spending someone else's money are too busy chiming in with the more expensive fixes.
But, some traction bar snubbers or suspension bushings. Take the stock bump off the lower control arm. On the snubber you can install fender washers(very large OD washers) to space the snubber up as much as possible. This will not control the wheelie problem. Just keep from tearing up so much when you land. It will also limit bump steer and the car is not allowed to go so deep into the bounce.
Bump steer is easy to check when on a budget. Simply, get someone to stand over in the engine bay and bounce the car up and down. Watch the front tires and see what they do. If they turn in and out well you have bump steer issues. Sometimes just raising or lowering the front end will fix the major problems. Your upper control arm should appear to be level. If the car is too low or high in the front it puts the upper control arm at an angle then the top of the tire is being pulled towards center of the car when the suspension goes in that direction. Don't know whether your car sits low or high so don't know if or in what direction the problem could exist. I have found tons of Mopars that people got happy cranking on torsion bars and seriously screwed up the way the front end works.
Just my 2 cents. Good luck
Leon
