Re: 4.7 in Dakota [Re: Crazy68Dart] #1449582
06/10/13 11:13 AM
06/10/13 11:13 AM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
165k on the 4.7 in the wife's 01 2wd Durango. Great power but mpg is nothing to write home about. No issues with oil usage or anything like that. Had to replace the auto trans at about 135k.
Re: 4.7 in Dakota [Re: G_bob] #1449583
06/11/13 11:22 PM
06/11/13 11:22 PM
Canton, Ohio
Crazy68Dart Offline OP
Canton, Ohio
Looked at the truck tonight. Pretty nice little truck. Overall solid, driver's side door has some rust in the front lower and rear lower corners. Underside of the truck is really clean.
Engine sounds perfect. No signs of anything unusual. Oil looked good, no signs of coking oil on the dip stick or fill reservoir. Sure looks a lot different than my 350... lol. Mileage is not much better. Has 3.55s in the rear.
Top of the bed rails looks like the clear coat is starting to go, had a white-ish look to it. I think I could hide most of it with a set of stick on bed rail caps from Summit. Little concerned if the rest of the truck will start to do the same.
Needs an exhaust (original) and will need tires sooner than later. Probably would get the rust in the door handled too before it gets out of control.
I just need to decide now WTF to do. Decisions... decisions...
383, Hemi 4-Speed, AlterKtion, D60
Re: 4.7 in Dakota [Re: Crazy68Dart] #1449584
06/11/13 11:40 PM
06/11/13 11:40 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Dodge used crappy clear coat in those years. Clear coat peel is common on these trucks, especially if they are used as trucks and parked outside all the time. If the bed rails are going, the other horizontal surfaces are not far behind. Only fix is to sand down past the clear, and re-shoot color/clear
...if that helps you decide
**Photobucket sucks**
Re: 4.7 in Dakota [Re: 70Cuda383] #1449585
06/12/13 07:55 AM
06/12/13 07:55 AM
Canton, Ohio
Canton, Ohio
It actually does, thanks. I think I am going to pass and get my current truck fixed up a bit. Or, just drive it until the wheels fall off and not worry about what it looks like.
Thanks.
Re: 4.7 in Dakota [Re: Crazy68Dart] #1449586
06/12/13 09:26 AM
06/12/13 09:26 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
2001 Durango 2wd and 135,000 miles. Had to replace both ex manifold gaskets and fan clutch. Gets around 12 mpg around town and abount 18 mpg on the road. Tows beter than my 78 camper special did. I wish I had a later model so I could tune it more. all in all it's been a good vehicle
Re: 4.7 in Dakota [Re: babarracuda] #1449587
06/12/13 10:15 AM
06/12/13 10:15 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
My 4.7L Durango SLT Plus AWD has 176K on it. I bought it used with 12K on it. Replaced water pump, replaced radiator, three batteries, two sets of tires, one set of plugs. Nothing else has been touched. 15.5MPG mostly city. Passes the second most strict emissions in the country. Towed with it 5 times a year in the Rockies, once over Trail Ridge road, the highest continuous road in the nation. Oil changed seasonally (four times a year), about 5500 miles between changes.
All in all, the best vehicle I have ever owned.
Craig
Re: 4.7 in Dakota [Re: Crazy68Dart] #1449588
06/12/13 03:52 PM
06/12/13 03:52 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
FWIW, '88 was when the 4.3/5.0/5.7 went to the roller cam. '96 is when they went to the Vortech heads on the v8s. I think the 4.3s were a few years earlier, maybe '94 for the Vortech heads.
On the rust, yeah I know... It is not worth it if there is any indication of rust starting. I am going to go look at the Dakota this week. I tend to crawl all over (and under!) vehicles when I buy, so I'll take a good look at the under side, brake/fuel lines, cab corners, rockers, doors, wheel openings, etc.
Chevy truck 305 and 350s did NOT get the roller cam until 96 when they went Vortech, I have rebuilt quite a few including one last week and another (95) on the stand right now.
Re: 4.7 in Dakota [Re: Crazy68Dart] #1449589
06/12/13 06:08 PM
06/12/13 06:08 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
I have an 03 with 5 speed and quad cab had 20,000 on the odo and now 93,000 still has all original stuff other than changing the t-stat and some wierd air pockets in the cooling system it has been a really reliable truck for me and it has tons of torque ,drop the clutch and hammer it its an e ticket ride..
Re: 4.7 in Dakota [Re: HotRodDave] #1449590
06/12/13 10:39 PM
06/12/13 10:39 PM
Canton, Ohio
Canton, Ohio
Looks like you are correct. Sorry about the misinformation. The 4.3s were roller and evidently autos, but not trucks until '96. Good to know. I did heads and intake on a friends '88 350 in his 1500 and I would bet money that it had roller lifters. This was 10+ years ago. Guess my memory is getting bad.
Back to the Dakota... took the '95 GMC to a few shops for rust repair quotes. One wanted 2200 the other 3200. This is a 20' truck, with very little visible rust. Just happens that the cab corners need done, and some rust is just starting on three of the four wheel openings. Also was to blast and paint the bottom of the door edges which are just starting to show some corrosion. *sigh*
I might be getting the Dakota after all and just deal with the clear coat issue. We'll see.
Re: 4.7 in Dakota [Re: Crazy68Dart] #1449591
06/12/13 11:49 PM
06/12/13 11:49 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
The roller cam thing was odd, as I worked on chevies at a chevy dealer from 1984 thru 1998 and did just eng work. Saw all the things that they improved on and all the things they messed up, and had to correct. Still good trucks, and I drove old dodge 4x4's the whole time I was there. Was simply my preferance.
