Re: Radiator Cap ?
[Re: scratchnfotraction]
#1449417
06/08/13 09:00 PM
06/08/13 09:00 PM
RapidRobert
A recovery cap will have the thin brass disc on the bottom of the rubber seal & it's loose. To use it you'd fill the system up to the neck flange where the neoprene seal seats & run a hose to the bottom of a recovery bottle. It reportedly helps prevent rust as it eliminates the 1&1/2" or so air pocket below the neck which makes sense & when it came out in the 70's it also reportedly dropped temps up to 10 degF from more uniform/better cooling. Even if you dont have a hose to the bottom of the bottle just fill the rad all the way up to the neck & let it puke & find it's own level but for the minor effort of adding a longer hose I would suggest it if the cap has a loose brass disc which tells you it's a recovery cap. A vented cap will vent to the hose nipple on the side of the rad cap flange to the ground or to a bottle using the lever & it's a safety feature to protect an uninformed motorist from scalding himself & sueing Stant. Not sure if the lever caps are available in a recovery cap (which have the loose brass disc)(or not)but I think they are since with a recovery system they want you to check fluid at the bottle and not at the cap & to let the system work the bottle needs to be kept partly filled so it dont suck air back in & defeat the recovery purpose & with a homemade bottle you want the cap on top on tight to stop evaporation
Re: Radiator Cap ?
[Re: RapidRobert]
#1449418
06/08/13 09:30 PM
06/08/13 09:30 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
I run the cap with the thermometer in it from Summit.Mines a 16 pound on the 65.I think Mr.Gasket makes them.Looks good and no problems after 3 years.Plus you have another way to check the rad temp.No recovery bottle on mine.Rocky
Chrysler Firepower
Re: Radiator Cap ?
[Re: therocks]
#1449420
06/09/13 09:19 AM
06/09/13 09:19 AM
Posts: 277 Palmyra, NY
63stabamatic
Palmyra, NY
Rocky what is the part number of your Summit cap? I ordered one of those from Summit, had to send it back, it was for a 1.5 Inch cap opening radiator, all my cars are 2.0 inch.
Re: Radiator Cap ?
[Re: 63stabamatic]
#1449421
06/09/13 11:47 AM
06/09/13 11:47 AM
therocks
Niles , Ohio
I run the MRG-2471-r cap.Thats a 16 pound red cap.Fits my 65 stock rad perfect.No problems.Rocky
Chrysler Firepower
Re: Radiator Cap ?
[Re: mopars4ever]
#1449424
06/09/13 04:19 PM
06/09/13 04:19 PM
Posts: 13,615 md
mopars4ever
md
Found this too. http://www.slantsix.org/forum/viewtopic.php?t=12606With lower ring only, with free-hanging centre valve (Partial-pressure, open system) With lower and upper ring, with free-hanging centre valve (Partial-pressure, coolant recovery system) With lower ring only, with spring-loaded centre valve (Full-pressure, open system) With lower and upper ring, with spring-loaded centre valve (Full-pressure, coolant recovery system).
