70 challenger 'shaker-hood' question #1449339
06/08/13 02:35 PM
06/08/13 02:35 PM
new york
P
paris401 Offline OP
paris401  Offline OP
P
new york
we have a 70 challenger with a shaker,wing,louvers.. that we were told when purchased were orig (not repop's).. we want to take off the items, sell em and return the car to original..
there must be #'s, but can't find any.. ideas where they are located..thanks
Re: 70 challenger 'shaker-hood' question [Re: paris401] #1449340
06/08/13 02:50 PM
06/08/13 02:50 PM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
Pics are better than numbers -
Tom
68 Charger
70 Cuda
Re: 70 challenger 'shaker-hood' question [Re: FC7cuda] #1449341
06/08/13 03:00 PM
06/08/13 03:00 PM
new york
P
paris401 Offline OP
paris401  Offline OP
P
new york
ok..here goes
Re: 70 challenger 'shaker-hood' question [Re: FC7cuda] #1449342
06/08/13 03:00 PM
06/08/13 03:00 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The only number (that matters) on the hood assembly is on the trim ring. It's cast into the ring (in tiny numbers) on the underside of the rear edge, you can't see it unless it's removed from the hood. However, if your ring is still unmolested and has all of it's original studs and nuts (no broken ones) I'd HIGHLY reccomend against trying to remove them as they break off VERY easily and are extremely difficult and expensive to properly replace. Removing one intact is a very delicate job.
The hood itself has no Shalke unique numbers, but good pics of the complete underside will make ID'ing one pretty easy. The one pic you posted looks to be an original hood, however, the kist I used to sell could be made to fool most (in pictures anyway) if installed perfectly with original style spot welds.
Re: 70 challenger 'shaker-hood' question [Re: paris401] #1449343
06/08/13 03:01 PM
06/08/13 03:01 PM
new york
P
paris401 Offline OP
paris401  Offline OP
P
new york
here is the shaker....
Re: 70 challenger 'shaker-hood' question [Re: paris401] #1449344
06/08/13 03:02 PM
06/08/13 03:02 PM
new york
P
paris401 Offline OP
paris401  Offline OP
P
new york
and the wing and louvers....
Re: 70 challenger 'shaker-hood' question [Re: paris401] #1449345
06/08/13 03:03 PM
06/08/13 03:03 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Post a pic of the Shaker bubble underside, there will be a casting number in the bubble near one side where the emblem holes are. Also, the grills have casting numbers in them.
Re: 70 challenger 'shaker-hood' question [Re: ScottSmith_Harms] #1449346
06/08/13 03:24 PM
06/08/13 03:24 PM
new york
P
paris401 Offline OP
paris401  Offline OP
P
new york
here is a pic of the underside... - I see a pentastar on the driver's side under the callout... there are some numbers, but will need someone to hold up the shaker, and i'm alone at the mom..
Re: 70 challenger 'shaker-hood' question [Re: paris401] #1449347
06/08/13 03:35 PM
06/08/13 03:35 PM
new york
P
paris401 Offline OP
paris401  Offline OP
P
new york
the numbers appear to be
V3418857
85148
Re: 70 challenger 'shaker-hood' question [Re: paris401] #1449348
06/08/13 06:28 PM
06/08/13 06:28 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Tough to say 100% but that all appears to be original, there are very close/accurate reproductions of the grills and hot & cold air doors out there, you really need to see them first hand to spot them. The bubble itself shows all outward signs of being an original.
