R5P7 in a 4 spd B- Body? #1449299
06/08/13 12:10 PM
06/08/13 12:10 PM
USA
hudsonhornet7x Offline OP
USA
Does this sound like a dumb idea for a heavy car? Are their any bellhousings that will fit it onto a 833 4 speed?
Re: R5P7 in a 4 spd B- Body? [Re: hudsonhornet7x] #1449300
06/08/13 03:46 PM
06/08/13 03:46 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Bobsprofab makes an adapter. Don't know if you could use the NASCAR bell with an 833. If that worked you could save a lot of aggravation.
If you have a stock K-member or even a tubular you are going to either raise the engine to the sky or need to get a custom pan done. You could make a wet sump pan and run a single stage pump but, you have to do some work to the engine so the oil can drain from cam tunnel to pan.
Re: R5P7 in a 4 spd B- Body? [Re: Leon441] #1449301
06/08/13 10:16 PM
06/08/13 10:16 PM
IL. Jerseyville
jg309 Offline
jg309  Offline
IL. Jerseyville
the833 willnot fit the nascar bell
Re: R5P7 in a 4 spd B- Body? [Re: jg309] #1449302
06/09/13 10:14 AM
06/09/13 10:14 AM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
A Nascar bellhousing is also designed for a small clutch. They are, however, available for cheap money, and would be worth experimenting with.
Re: R5P7 in a 4 spd B- Body? [Re: TrWaters] #1449303
06/09/13 11:36 AM
06/09/13 11:36 AM
Glendale, AZ
Dave W Offline
Dave W  Offline
Glendale, AZ
I have everything you need. Fresh R5/P7 complete engine, stainless tri-y headers, bell housing with 7.25" triple disc clutch and flywheel along with the starter. All for $5500! PM me if interested.
Re: R5P7 in a 4 spd B- Body? [Re: Dave W] #1449304
06/09/13 09:04 PM
06/09/13 09:04 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Jesse ran a 833 when he installed his P7 engine into his Duster, pretty sure he ran an adapter to do so
Alan Jones
