440 6PACK distributor #1449246
06/08/13 10:30 AM
06/08/13 10:30 AM
S.W. Florida
blkbee6pack Offline OP
S.W. Florida
My 1970 6 pack Bee has a SBD of 3/20/70, Motor assy., Feb. 1970 There are two distributors in Galen's book, 2875982 early, and 348349 late, both for 1970 440-6 auto. Which one would be for my car, or either. Also how far out on date code? THANKS
Re: 440 6PACK distributor [Re: blkbee6pack] #1449247
06/08/13 01:11 PM
06/08/13 01:11 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
You would most likely have the later. The cut off is approximately January 1, 1970 taken from the 1970 parts manual. 3438349 IBS-4019A
Re: 440 6PACK distributor [Re: Morty426] #1449248
06/13/13 10:47 AM
06/13/13 10:47 AM
S.W. Florida
S.W. Florida
That's what thought, but I think the parts manual calls for the 3438349 IBS-4019A to have the electronic vacuum advance. I have never seen a 70 6Pack with one.
Re: 440 6PACK distributor [Re: blkbee6pack] #1449249
06/15/13 09:45 AM
06/15/13 09:45 AM
S.W. Florida
S.W. Florida
Any one?
Re: 440 6PACK distributor [Re: blkbee6pack] #1449250
06/15/13 06:49 PM
06/15/13 06:49 PM
New York
Mopucky Offline
Mopucky  Offline
New York
I have a 3438356 IBS-4019AS It has the electronic part on the vacuum advance. I had it for a 70 V code I sold.
Re: 440 6PACK distributor [Re: Mopucky] #1449251
06/16/13 11:06 AM
06/16/13 11:06 AM
S.W. Florida
S.W. Florida
The 3438356 is the replacement one, what is the date code? Any one with a 3438359 that has the elec., vacuum on a 70 model 6pack?
Re: 440 6PACK distributor [Re: blkbee6pack] #1449252
06/21/13 10:45 AM
06/21/13 10:45 AM
S.W. Florida
S.W. Florida
Has no one ever seen or restored a late production 70 6pack car with the 3438349 distributor and did it have an elec., vacuum advance?
Re: 440 6PACK distributor [Re: blkbee6pack] #1449253
07/03/13 08:51 AM
07/03/13 08:51 AM
S.W. Florida
S.W. Florida
Any one?
Re: 440 6PACK distributor [Re: blkbee6pack] #1449254
08/04/13 11:39 AM
08/04/13 11:39 AM
S.W. Florida
S.W. Florida
Any one? With all the 70 6packs restored, there has to be one with this distributor.
Re: 440 6PACK distributor [Re: blkbee6pack] #1449255
08/04/13 08:20 PM
08/04/13 08:20 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
I have the earlier distributor which is dated 519. My car's SPD is Feb 10, 1970. I think you would be fine using that one for your car if you could locate one. I would think that the factory would use up the earlier distributors first, before changing to the others. Since the one I have was dated the second last week of 1969, that would indicate to me that if that Jan 1970 date was an absolute cut off date, the earlier Prestolite ones would have ceased production much earlier than the end of 1969. Am I making sense?
Re: 440 6PACK distributor [Re: blkbee6pack] #1449256
08/06/13 10:22 AM
08/06/13 10:22 AM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Never seen an electronic vacuum on an original 70 440-6 dual point.
