D250 grille swap question #1449244
06/08/13 09:55 AM
06/08/13 09:55 AM
NC
jwmotors Offline OP
jwmotors  Offline OP
NC
I have a 87 D250 that needs a grille surround , and headlight doors.
I have a nice grille surround for a 1985 model truck. I wonder if the 85 surround would work on the 87 . I do not have the headlight doors for the 85 surround so I cannot just try the stuff.My concern would be if the radiator support could be different and locate the headlights in a different place.
Re: D250 grille swap question [Re: jwmotors] #1449245
06/08/13 10:25 AM
06/08/13 10:25 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Been discussed several times. The difference is VERY small. The lights are off slightly but it'll go right on. Some have said they had to clearance the headlight opening just a tad to fit proper. But Yes it will fit
