904 swap help. #1449182
06/08/13 05:22 AM
06/08/13 05:22 AM
California
shamefulcuda Offline OP
California
I'm wondering if a 904 trans out of a 85 dodge truck will work in my 72 challenger? He also has a 904 out of a 78 dodge but he doesn't know if it works, would that also work in my car ok? I'm just trying to get my chally moving this weekend. The 904 in truck I can drive so I know it works. Just seems to new to work in my car as I wasn't aware they still were producing 904s then. Thanks for any help
Re: 904 swap help. [Re: shamefulcuda] #1449183
06/08/13 05:54 AM
06/08/13 05:54 AM
Tennessee
meep_meep Offline
meep_meep  Offline
Tennessee
It's the same transmission, except for the speedo gear and housing will have to be swapped from your old transmission...
Re: 904 swap help. [Re: meep_meep] #1449184
06/08/13 08:54 AM
06/08/13 08:54 AM
scratchnfotraction Offline
use the TP valve lever and the gear selector lever from the trans in your car along with the speedo gear/housing.
that keeps the linkage correct for the car and speedo correct.
85 truck may or may not have the lock-up trans,you tell by the input shaft on them.
your 72 904 would be non lock up,the 78 904 maybe non lock up
lock up =better MPG
non lock up = more perfomance
splines to the end are non-lock up
1.5" smooth end on tip of input is a lock up
the TC between the 2 do not mix.
Re: 904 swap help. [Re: scratchnfotraction] #1449185
06/08/13 01:12 PM
06/08/13 01:12 PM
California
California
So my 72 is non lock up trans, but if the truck one ends up being a lock up trans as long as I use the converter out of the truck as well I'm ok? Thanks this is really helpful
Re: 904 swap help. [Re: shamefulcuda] #1449186
06/08/13 07:40 PM
06/08/13 07:40 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Maybe.
Depends on what engine is in front of the 904, 318 in both then yes. I'll assume it's a V8 here, I suppose it could be a slant 6 in both.
They make 904 type transmissions till 89 in the M bodies,
Don't be the exception.
Re: 904 swap help. [Re: Supercuda] #1449187
06/08/13 08:22 PM
06/08/13 08:22 PM
Maybe.
you wont really know till you pull it out and ID it...72 could of had a trans replaced with anything by 2013.
post the # along the edge of trans pan rail from driver side..this will tell what yr the case is. but agian, many things could have been done to it since then on the inside.
Re: 904 swap help. [Re: shamefulcuda] #1449188
06/08/13 09:11 PM
06/08/13 09:11 PM
central CT
cudazappa Offline
cudazappa  Offline
central CT
If your 72 is a floor shift the truck trans may not have the boss cast in it for the floor shift bracket. BTDT.
1971 Challenger
Re: 904 swap help. [Re: cudazappa] #1449189
06/08/13 09:48 PM
06/08/13 09:48 PM
thats a very good point and something to watch for with floor shifters
