Hi All!
I have had problems with a corroded power steering pulley causing the belt to slip. Now I need to do something about it.
First: I checked with Year One for a new pulley but apparently the BB and SB pulleys differ and they had none for SB. Where could I get a new stock appearance pulley for a small block? I have the Federal pump with a 7" three spoke pulley.
Second: In my efforts to get this to work I might have over tensioned the belt for a short period. Could I have ruined the pump? There is some play back and forth on the pump axle. Is this normal?
I really would hate to do all the work and hassle to change the pulley only to discover it was not sufficient and having to change the pump too. I live in Sweden and this seems to be a hard to find part over here. Both pulleys and pumps...
How would you recommend me to approach this?
Thanks for all input,
Jörgen
Sweden
