Correct length for E-body turn signal lever? #1448691
06/07/13 08:34 AM
06/07/13 08:34 AM
Toronto (YYZ) Ontario
YYZ Offline OP
YYZ  Offline OP
What are the correct lengths for the E-body turn signal levers? Without cruise control.
Application would be '70-'71 with the standard woodgrain wheel or rim-blow.
Thanks in advance
Re: Correct length for E-body turn signal lever? [Re: YYZ] #1448692
06/08/13 11:36 PM
06/08/13 11:36 PM
Alberta, Canada
4004spd Offline
4004spd  Offline
Alberta, Canada
Hi Vlad, this is from my 71 Barracuda and is about 7 1/2" to the bend. From the bend over it's about another 1 1/4".
Car has the standard wheel, hope it helps!
Brian
Re: Correct length for E-body turn signal lever? [Re: 4004spd] #1448693
06/08/13 11:38 PM
06/08/13 11:38 PM
Alberta, Canada
4004spd Offline
4004spd  Offline
Alberta, Canada
other pic. take care!
