Fly wheel ID 143 tooth #1448323
06/06/13 12:38 AM
06/06/13 12:38 AM
Clay Co. Tenn.
sampson78 Offline OP
Clay Co. Tenn.
I have a 143 tooth flywheel. I have tried to run the numbers. how can I tell if it is for netural balance of external. Or will I have to take it to a machine shop. I don't even know where it came from. Any help would be appreciated. Cliff
Re: Fly wheel ID 143 tooth [Re: sampson78] #1448324
06/06/13 12:56 AM
06/06/13 12:56 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Are there weights or drill holes on the backside?
...well, wait. Weights would be a sure sign of external balance... I suppose a neutral balance could still have holes drilled on it to correct it back to neutral.
No numbers anywhere? Safest bet is to have someone soon it to test it and see if its neutral or not
**Photobucket sucks**
Re: Fly wheel ID 143 tooth [Re: 70Cuda383] #1448325
06/06/13 02:18 AM
06/06/13 02:18 AM
dogdays Offline
dogdays  Offline
Pictures! We must have pictures!
R.
Re: Fly wheel ID 143 tooth [Re: sampson78] #1448326
06/07/13 07:06 PM
06/07/13 07:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The casting number on the flywheel is useless for ID because the same basic casting can be drilled for external balance or not. IOW, the part number changes but the casting number doesn't.
Re: Fly wheel ID 143 tooth [Re: John_Kunkel] #1448327
06/12/13 02:30 AM
06/12/13 02:30 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
One or two small holes is an indication of zero balance or internal balance. On the crankshaft side of the flywheel, if I remember correctly, mopar machines part of the material away. It'll be a fairly significant amount. If you have some way of putting it on some V blocks, an external flywheel should self align itself with the weight to the bottom. Whatever mandrel you use needs to fit the center of the flywheel pretty tight, it can't be sloppy.
