Small block adjustable timing pointer
#1448246
06/05/13 10:15 PM
06/05/13 10:15 PM
Posts: 171 Indy
moparman89
Indy
Is there such a thing produced? Using a Summit SFI damper and I'm not a fan of using the marks on the timing cover.
School of Automotive Machinists Racing
Re: Small block adjustable timing pointer
[Re: moparman89]
#1448247
06/05/13 11:14 PM
06/05/13 11:14 PM
RapidRobert
I'm not sure but an option would be to check/find exact TDC then make your own marks as needed by measuring a strip of paper & using it as a ruler to make em CW around the circumference from the TDC slit. 0.0632683" is (1) degree. I make marks at 10-15-20-35 & that's plenty as it's easy to gauge when you're halfway between 15 and 20 for instance. Use white paint. 2&1/4 (2.246") is 35.5 degrees total
[Re: moparman89]
#1448250
06/06/13 08:05 PM
06/06/13 08:05 PM
RapidRobert
What about swapping the late timing cover for an early one or vice versa. It'd put the marks on the opposite side & give you a cleaner look (just a suggestion)
[Re: Pacnorthcuda]
#1448252
06/06/13 10:41 PM
06/06/13 10:41 PM
Posts: 171 Indy
moparman89
Indy
Yall arent understanding what I'm saying here. On a typical setup, the timing cover has marks on it and the damper has corresponding marks on it (marks towards the timing cover).
This damper I have has the timing marks on the opposite edge(damper bolt side). Yes I could scribe lines across the damper, but I would like to use a pointer similiar to a SBC which hangs over the damper.
[Re: Pacnorthcuda]
#1448253
06/06/13 10:51 PM
06/06/13 10:51 PM
moparpollack
Lil Herman
Lil Herman
85086
Why not just buy a timing tape?
I would go this route.
[Re: moparpollack]
#1448254
06/07/13 01:19 PM
06/07/13 01:19 PM
Posts: 1,009 Richmond Twp. Mi.
Mr340
Richmond Twp. Mi.
Here's the one i made for that type of set up. it attaches to the bottom of the h2o pump.
[Re: Mr340]
#1448256
06/07/13 03:22 PM
06/07/13 03:22 PM
Posts: 1,465 Carson City, NV
babarracuda
Carson City, NV
You have mixture of early and late timing cover and dampner. if the cover has the marks on the right side and the timing marks are on the right side, get a newer cover. If the oposite is true then you need an early SB timing cover. A short cut is the fastest way to where you do not want to go!!
[Re: babarracuda]
#1448257
06/07/13 06:53 PM
06/07/13 06:53 PM
Mr340
Richmond Twp. Mi.
The damper was an aftermarket and would not clear the cast in timing marks so I used a early model cover that has no timing marks and fabbed the pointer. I think what the OP is saying is that the tmg marks on the damper are towards the front face of the damper and don't extend to the rear where the cast in mark are on the cover, it's not a right/left thing
Gary
[Re: Mr340]
#1448258
06/07/13 11:44 PM
06/07/13 11:44 PM
Posts: 171 Indy
moparman89
Indy
Gary
Exactly. Going to make one out of a SBC version.
