Re: Problem with GC trans Made a bang
[Re: 69Mannix]
#1448096
06/05/13 07:53 PM
06/05/13 07:53 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
if GC stands for grand caravan I have seen a lot of broken axel shafts which is an easy fix, I have also seen a number of them snap the splines out of the planets that means removing the trans and taking it completely apart.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: Golden-Arm]
#1448098
06/06/13 07:58 PM
06/06/13 07:58 PM
dusturbd340W5
Kissimmee Fl.
if that's the case I would check out the T-case first.
[Re: 69Mannix]
#1448101
06/10/13 11:23 AM
06/10/13 11:23 AM
Posts: 5,302 CA, Proprietor; The "PALOMINO"...
dynotune440
it should not be too bad to replace. if it is an 06, and your the original owners, that had lifetime powertrain.. I would honestly look into LKQ for a used one... No transmission shop will guarantee one that is not completely gone through.... Glad to hear you coming back stateside...
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
[Re: dynotune440]
#1448102
06/10/13 02:36 PM
06/10/13 02:36 PM
Posts: 1,214 Newberry Springs, CA
69Mannix
I am glad to come home, The situation sucks
