Where to get rear axle brake tee #1447997
06/05/13 05:15 PM
06/05/13 05:15 PM
6T4 Polara Offline OP
I need a rear axle brake tee the style that mounts using the breather to the axle.
This is for a B Body 1968 model year.
John
Re: Where to get rear axle brake tee [Re: 6T4 Polara] #1447998
06/05/13 05:19 PM
06/05/13 05:19 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I think they come on the end of the hose? But I'm not positive. They do on a E body.
Re: Where to get rear axle brake tee [Re: Challenger 1] #1447999
06/05/13 08:08 PM
06/05/13 08:08 PM
Separate block mounts on the axle.
Re: Where to get rear axle brake tee [Re: 6T4 Polara] #1448000
06/05/13 08:28 PM
06/05/13 08:28 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
NAPA has them.
Re: Where to get rear axle brake tee [Re: topside] #1448001
06/06/13 06:24 PM
06/06/13 06:24 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
Re: Where to get rear axle brake tee [Re: Joesixpack] #1448002
06/06/13 07:15 PM
06/06/13 07:15 PM
Cincinnati, Ohio
Cincinnati, Ohio
Re: Where to get rear axle brake tee [Re: Challenger 1] #1448003
06/06/13 08:57 PM
06/06/13 08:57 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
Dr Diff
codfish
Re: Where to get rear axle brake tee [Re: codfish] #1448004
06/08/13 12:50 PM
06/08/13 12:50 PM
Got one locally from a member.
Thanks again Dave.
