Re: I want 2 1/2 inch exhaust right?
[Re: dogdays]
#1447407
06/04/13 01:21 PM
06/04/13 01:21 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
the pypes system looks like a pretty good value http://www.summitracing.com/parts/pye-sme11sstainless pipe, Xpipe and stainless mufflers for $400? granted you're on your own from the front of the system to the manifolds... I second the motion on the 17748/49 large body turbos, but they are big, and may not fit.
[Re: cudabitten]
#1447408
06/04/13 01:59 PM
06/04/13 01:59 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I only needed a 2.5 system for my challenger behind a mild 413, but went 3" so when I build a better engine I won't have to upgrade the exhaust. Something to think about.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: cudabitten]
#1447409
06/04/13 05:08 PM
06/04/13 05:08 PM
RapidRobert
2&1/2" would be adequate for your current eng but I would suggest mandrel bends for less restriction and an X pipe & extra glasspacks or resonator muffs along side the rear springs for more sound control & more sound control lets you run a less restrictive for more power but (louder) muffs while still staying within your comfort zone. A 3" system might gain a slight bit as I believe any neck down past the collector flange restricts flow & therefore power & that correct velocity (pressure wave tuning) is strickly a function of the primary tubes & a 3" system would certainly be the way to if a larger eng might come later but it'd be WAY louder. Ideal would be a 3" mandrel system (at least to/including the cutout) then with restricted muffs then a electrically or vacuum operated ex cutouts which'd be reasonably quiet in normal operation then loud & full power on demand when needed but would be way beyond your (stated) budget
