Re: 340 six pak carbs?
[Re: Cab_Burge]
#1447259
06/04/13 01:06 PM
06/04/13 01:06 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Same as the 440 carbs, 500 CFM for each out board, 350 cfm center
That sir is not correct, the 340 center carb is smaller in CFM than the bigger 440 carbs.
Ummmmmm..........no, if you want to get technical, the largest center carb is actually the 4791 manual 340 center rated at 355 cfm, and 350 cfm for the 340 4792 auto carb, the 440 centers auto or manual are rated at 350 CFM each
mike
[Re: DAYCLONA]
#1447260
06/04/13 04:52 PM
06/04/13 04:52 PM
Posts: 43,317 Bend,OR USA
Cab_Burge
mike
That is not what we where told years ago by the Mopar drag seminar tech instructors ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: macmic87]
#1447262
06/04/13 11:27 PM
06/04/13 11:27 PM
Posts: 18,160 Mass
DAYCLONA
Mass
was there also a difference in the kill bleed size from small block to big block?
Yes, the 340 carbs have the larger diameter air bleed orifices
mike
