Axle studs? #1446029
06/01/13 01:27 PM
06/01/13 01:27 PM
London Ontario Canada Eh
Dono Offline OP
Dono  Offline OP
We dropped in a 8.25" rear into my sons 1985 dodge ram pickup truck. The rear was out of a car and narrower than the truck one as well as having small bolt patter and posi gear set.
We need to get some 3" studs to pound into the stock axles. Anyone know off hand what studs we should order from summit for these? Any off the shelf part numbers that may work for this appz?
Cheers Don.
Re: Axle studs? [Re: Dono] #1446030
06/01/13 01:39 PM
06/01/13 01:39 PM
N
NITROUSN Offline
NITROUSN  Offline
N
http://www.moroso.com/catalog/categorydisplay.asp?catcode=25107
Most likely the 46190 will be the one. I would measure first.
Re: Axle studs? [Re: Dono] #1446031
06/01/13 02:14 PM
06/01/13 02:14 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Trucks use the same ones as cars. Just ask Doctor Diff
Re: Axle studs? [Re: 76dodgeboy] #1446032
06/01/13 05:27 PM
06/01/13 05:27 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I didnt know that a GM "posi" unit would fit a Chrysler 8.25 rear axle.
I am truckless..
Re: Axle studs? [Re: 340SHORTY] #1446033
06/01/13 05:54 PM
06/01/13 05:54 PM
Lehigh Acres, Florida
rickstershemi Offline
Don't you start that crap again....lol
Rickster
Re: Axle studs? [Re: rickstershemi] #1446034
06/01/13 08:35 PM
06/01/13 08:35 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: Axle studs? [Re: 340SHORTY] #1446035
06/19/13 01:07 PM
06/19/13 01:07 PM
Dono Offline OP
Dono  Offline OP
46190 look to be the ticket thanks guys
Cheers Don.
Re: Axle studs? [Re: Dono] #1446036
06/21/13 10:44 PM
06/21/13 10:44 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Unfortunately, the Moroso lug studs don't fit Mopar axles.
I recommend Mr Gasket #4311. http://www.summitracing.com/parts/mrg-4311
