Page 1 of 3 1 2 3
P-V clearance with MP 590? *DELETED* #1444712
05/30/13 11:55 AM
05/30/13 11:55 AM
Grand Rapids, MI
11secondC Offline OP
Grand Rapids, MI
Post deleted by 11secondC
Re: P-V clearance with MP 590? [Re: 11secondC] #1444713
05/30/13 12:05 PM
05/30/13 12:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Put a test spring on the intake and the exhaust and
test your own set up... use a dial indicator and at full
lift push down on the rocker and measure the distance
Re: P-V clearance with MP 590? [Re: MR_P_BODY] #1444714
05/30/13 12:39 PM
05/30/13 12:39 PM
Grand Rapids, MI
Grand Rapids, MI
Uh, thanks for nothing? I wouldn't have asked the question if I had the tools to do so...
Re: P-V clearance with MP 590? [Re: 11secondC] #1444715
05/30/13 01:10 PM
05/30/13 01:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Do what you want..... last time I try to help you..
plus you better tell them what ratio rockers
Re: P-V clearance with MP 590? [Re: 11secondC] #1444716
05/30/13 01:21 PM
05/30/13 01:21 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Wow what a jerk of response! I doubt you will get any info or a response from anyone else on this board. Mike is very well thought of by everyone on here.
Old Geezer Racing
Re: P-V clearance with MP 590? [Re: 11secondC] #1444717
05/30/13 02:15 PM
05/30/13 02:15 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Maybe you should borrow the tools to do so , unless someone has your exact combination with everything machined exactly the same it's a guess at best and I would NOT trust a guess .
How was that for less than nothing ?
Re: P-V clearance with MP 590? [Re: SCATPACK 1] #1444718
05/30/13 02:16 PM
05/30/13 02:16 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
X2
Re: P-V clearance with MP 590? [Re: 11secondC] #1444719
05/30/13 02:22 PM
05/30/13 02:22 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Too funny..........go ahead and run it you`ll be fine ESPECIALLY above 8000 rpm`s............let us know how it works for ya. Born in 76 so you must know everything......
Re: P-V clearance with MP 590? [Re: rt66jim] #1444720
05/30/13 02:25 PM
05/30/13 02:25 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Yep the only way you'll know for sure is to use checker springs and a degree wheel and a dial indicator. Moving the installed centerline shifts your P/V clearance also. Anyone can tell you sure it will fit, but without checking it correctly you could eaily loose a motor or extensively damage it. If you can't do it yourself find a friend or a shop that can. Dave
Re: P-V clearance with MP 590? [Re: Thumperdart] #1444721
05/30/13 02:26 PM
05/30/13 02:26 PM
Grand Rapids, MI
Grand Rapids, MI
The clique's on here are funny.
About what I expected, understandable since my screenname isn't bbodybob or abodyjoe...
Re: P-V clearance with MP 590? [Re: 11secondC] #1444722
05/30/13 02:28 PM
05/30/13 02:28 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
ATTITUDE pal..............plain amd simple..........
Re: P-V clearance with MP 590? [Re: 11secondC] #1444723
05/30/13 02:30 PM
05/30/13 02:30 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
thats a crappy resopnce on your part.different engines have different variables.
Re: P-V clearance with MP 590? [Re: 11secondC] #1444724
05/30/13 02:42 PM
05/30/13 02:42 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Zero deck 440 with SRP's flat-tops -6cc valve reliefs...MP 590, 75 cc Edelbrocks, Marine Fel-pro's...
Anyone run into issues with the cam in @ 102-104?
are you running this cam now ? if so what is it in at and what is your current piston to valve clearance?
The only cliques are those that people create for themselves.
Re: P-V clearance with MP 590? [Re: ro23car] #1444725
05/30/13 02:47 PM
05/30/13 02:47 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Well I have very close to the same combo..But not sure I want to tell you anything !!....gezz man chill out.. Now I have a lot of valve to piston clearnce.. same cam- flat top pistons. 0 deck- stock crank-stock length rods- 1.5 rockers. over .150 on both intake and exhaust . But you really should not take anyone word on this.. bad things can and will happen if it is not right..I would have to look and see what size my relieves are.cam is in at 101. heads are 72cc.
Re: P-V clearance with MP 590? [Re: VernMotor] #1444726
05/30/13 02:58 PM
05/30/13 02:58 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
What your clearance Clarence, roger Roger, whats your vector Victor....
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: P-V clearance with MP 590? [Re: JohnRR] #1444727
05/30/13 03:04 PM
05/30/13 03:04 PM
Grand Rapids, MI
Grand Rapids, MI
John...I've seen similar questions by different posters that have been asked on this board before, not necessarily mine fwiw...and it's amazing the difference in responses given depending on who posted the question. Is what it is.
I completely understand the "correct" way, is to measure it and again I understand the catastrophic consequences if I get it wrong.
Currently running the MP557...no idea on where I'm at, again don't have the tools to check it. Been running now 2 years...a friend has offered a nib 590 he's never ran, thought maybe I would give it a shot. Cam has been around what 30+ years, and I'm guessing someone at one time has tried running it in a zero deck motor, if it worked with a old TRW 6 pak piston, I would think it should be ok with mine...might be I'm wrong, don't know.
I've actually met Mike in the pits a few years back, seemed like a nice enough guy...my apologies to him for being so curt...
Re: P-V clearance with MP 590? [Re: VernMotor] #1444728
05/30/13 03:09 PM
05/30/13 03:09 PM
Grand Rapids, MI
Grand Rapids, MI
Thanks, I appreciate it.
Re: P-V clearance with MP 590? [Re: 11secondC] #1444729
05/30/13 03:11 PM
05/30/13 03:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Hey smart a$$ your the one asking for answers... instead
of your snide remark you could have just said I
dont have the equipment to do it right... there
isnt any clique on here and we would have been more
than happy to try and help you ... MAYBE Jamie
(Vernmotors) can give you a ball park number
that you'll be happy with
Re: P-V clearance with MP 590? [Re: MR_P_BODY] #1444730
05/30/13 04:39 PM
05/30/13 04:39 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I'm not as knowledgable as Mike or some of the others on here but i used to run a .670 roller 280 at .050 dur with 6 pack pistons, 76 cc RPM's snd steel shim head gaskets and they cleared fine.
I run the .590 with the same heads now but with dome pistons and felpros. I clayed the pistons on both.
BTW, love your 66 Fury, you see very few 65-6 at the strip. I used to have a 66 Fury 111 with a 383.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: P-V clearance with MP 590? [Re: 11secondC] #1444731
05/30/13 06:40 PM
05/30/13 06:40 PM
saint paul mn.
johnzgarage Offline
johnzgarage  Offline
saint paul mn.
O.k. thats a SIMPLE QUESTION !!!!.....no. I have clayed out a flat top ross, zero deck , 63 cc stage6 head @ 104 1.5 rocker. Found no problems.
Page 1 of 3 1 2 3
