How little timing can I run and not hurt anything?? #1444186
05/29/13 12:17 PM
05/29/13 12:17 PM
Indy
FlyFish Offline OP
FlyFish  Offline OP
Indy
I have my small block stroker currently at 25° total timing. I'm wanting the car to slow down another 2 tenths, so I was going to pull the timing down a few more degrees...will this hurt anything? Can I run 20° total timing and not damage anything? I know it will cause more exhaust heat, but is that it?
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: How little timing can I run and not hurt anything?? [Re: FlyFish] #1444187
05/29/13 01:13 PM
05/29/13 01:13 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Can`t be a happy motor at that point I would think........why not tune it to perfection then limit full throttle. This reminds me of nos guys who retad their timing manually instead of using electronics killing power and TRYING to make it up w/nos but hey, that`s just my opinion.
Re: How little timing can I run and not hurt anything?? [Re: Thumperdart] #1444188
05/29/13 01:39 PM
05/29/13 01:39 PM
Indy
FlyFish Offline OP
FlyFish  Offline OP
Indy
I'm just trying to get this thing to run in Sportsman (12.0 bottom dial). I'm real close...just need a little more. This is what I have done so far:
I added as much weight to the car as possible (safely). I removed the secondaries on the carb (now its a 2 barrel), backed the timing off 10 degrees (25° total currently), and I'm short shifting at 5500 RPM (I normally shift at 6500). This combo has slowed the car a little over a second from high 10.7x ET to 11.87 (calculated from my 1000' time on my last 3 pass when I lifted at the 1000' cone and ran 12.05)....I just need to kill a little bit more to get to 12.0 so I don't have to coast the last 320'.
Re: How little timing can I run and not hurt anything?? [Re: FlyFish] #1444189
05/29/13 01:45 PM
05/29/13 01:45 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
From what I've been told by a former NASCAR engine build is you really don't want to rely on retarded timing to restrain the engine because the exhaust valve temps can skyrocket under those conditions.
Re: How little timing can I run and not hurt anything?? [Re: FlyFish] #1444190
05/29/13 01:46 PM
05/29/13 01:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You will be suprized how much timing you would need
to pull out to slow it .2.... what rpm do you launch
at... lower that and shift 500 less than you are shifting
now... I have a mech throttle stop on my dom set at
1/3 open and launch soft and shift real early to go 10.0
Re: How little timing can I run and not hurt anything?? [Re: MR_P_BODY] #1444191
05/29/13 02:11 PM
05/29/13 02:11 PM
Indy
FlyFish Offline OP
FlyFish  Offline OP
Indy
Unfortunately I can't shift any lower RPM, my converter flashes to a little over 5K, so I'm pretty much shifting as soon as I see the tach move (which is about 5500).
Re: How little timing can I run and not hurt anything?? [Re: FlyFish] #1444192
05/29/13 02:31 PM
05/29/13 02:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Put a mech throttle stop on it.. at part throttle the
conv flashes/stalls at a lower rpm due to not making
the torque like full throttle
Re: How little timing can I run and not hurt anything?? [Re: FlyFish] #1444193
05/29/13 03:08 PM
05/29/13 03:08 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
You are going to melt something , as it is your headers must be cherry red by the end of the pass .
Re: How little timing can I run and not hurt anything?? [Re: MR_P_BODY] #1444194
05/29/13 03:12 PM
05/29/13 03:12 PM
Indy
FlyFish Offline OP
FlyFish  Offline OP
Indy
So should I turn my timing back up to 35° (or close to it)?
Re: How little timing can I run and not hurt anything?? [Re: JohnRR] #1444195
05/29/13 03:13 PM
05/29/13 03:13 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Ever researched the "ET genie" ?
Re: How little timing can I run and not hurt anything?? [Re: J_BODY] #1444196
05/29/13 03:16 PM
05/29/13 03:16 PM
Indy
FlyFish Offline OP
FlyFish  Offline OP
Indy
Yeah, but I'm not dropping 500 bucks to go slower. I just want it slower for a few races.
Re: How little timing can I run and not hurt anything?? [Re: FlyFish] #1444197
05/29/13 03:24 PM
05/29/13 03:24 PM
JohnRR Offline
JohnRR  Offline
Can you run the class in your daily driver ?
What have you done to SAFELY ADD weight ? Adding weight is the best way to do it , can you swap steel you added for LEAD ???
I think the $500 will be cheaper than the potential damage you are going to do ....
Re: How little timing can I run and not hurt anything?? [Re: JohnRR] #1444198
05/29/13 03:38 PM
05/29/13 03:38 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
As already pointed out the only potential damage will likely be the exhaust vavels. Well it will also run a bit hotter normally with that much out of it.
Re: How little timing can I run and not hurt anything?? [Re: Al_Alguire] #1444199
05/29/13 03:43 PM
05/29/13 03:43 PM
Indy
FlyFish Offline OP
FlyFish  Offline OP
Indy
Ok, I'll put the timing back in it then. Thanks everyone....and yes, using my tow vehicle as a race car is sounding more and more likely for these races.
Re: How little timing can I run and not hurt anything?? [Re: FlyFish] #1444200
05/29/13 04:42 PM
05/29/13 04:42 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
Leaving in 2nd will get you close, you wont spin either, another trick is a restrictive little air cleaner
Re: How little timing can I run and not hurt anything?? [Re: wyoming] #1444201
05/29/13 04:56 PM
05/29/13 04:56 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Forced induction cars run 15-20 degrees, but that is with the aid of electronics and only when necessary
My forced induction job runs as little as 10 degrees at certain rpm/load conditions and exhaust temps don't pass 1100 degrees. That being said it isn't 10 degrees throughout the rpm range, and that is only under full load/boost conditions.
Re: How little timing can I run and not hurt anything?? [Re: GTX MATT] #1444202
05/29/13 05:52 PM
05/29/13 05:52 PM
JohnRR Offline
JohnRR  Offline
I didn't know that , but how does that help with a car not running forced induction and a timing computer ? He doesn't want to pony up the 5 bills for the ET thingamabob , I don't think he is going to pony up for forced induction so he can roll back the timing more ....
Re: How little timing can I run and not hurt anything?? [Re: JohnRR] #1444203
05/29/13 05:56 PM
05/29/13 05:56 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
To be more specific I should have said they run as little as 15-20 from the factory, because at certain points they will be in a normal 34+ range.
But still exhaust temps are reasonable, they should remain reasonable in an NA application, although my car also runs around 11-11.5:1 AFR under said conditions. I'm just playing devil's advocate.
Re: How little timing can I run and not hurt anything?? [Re: GTX MATT] #1444204
05/29/13 06:03 PM
05/29/13 06:03 PM
JohnRR Offline
JohnRR  Offline
Ever break in a cam with the timing at only 20-25 degrees ??? You won't get half way thru the break in before the radistor is boiling over ...
Re: How little timing can I run and not hurt anything?? [Re: JohnRR] #1444205
05/29/13 06:22 PM
05/29/13 06:22 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I wouldn't try to operate the engine at speed for extended periods of time with the timing retarded because it would surely overheat, but for a track car for 12 seconds at a time I think he will get away with it, just lock the timing out OR run vacuum advance on manifold vacuum to prevent overheating at idle.
At WOT my forced induction car sees the timing curve below, the car has been operated at WOT for in excess of 12 seconds many times without exhaust temperatures surpassing 1100 degrees.
I know that his car is not forced induction, and he SHOULD better explore other ways to limit his power, BUT
RPM Total timing
800 8.13
1200 13.05
1600 13.05
2000 12
2400 11.29
2800 9.89
3200 9.54
3600 9.54
4000 11.29
4400 12
4800 13.75
5200 16.21
5600 16.57
6000 19.03
6400 20.43
6800 23.25
