Need shifter part #
#1444175
05/29/13 11:38 AM
05/29/13 11:38 AM
Posts: 5,867 MA
Mass_Mopar
MA
I want to replace the shifter in my Charger. What part number do I need, and where have you guys bought from with success? Summitt? Jegs? somewhere else? '70, 383 4 speed, with console. Thanks
Re: Need shifter part #
[Re: JohnRR]
#1444177
05/29/13 12:09 PM
05/29/13 12:09 PM
Posts: 5,867 MA
Mass_Mopar
MA
Nick are you looking for the shifter box itself ? If so Brewer or Passon , 70 B body has it's on special shifter box with longer arms to make up for the longer arm of the of the B body pistol grip handle .
Be warned , it's not cheap.
Yep, this look about right?
http://www.brewersperformance.com/proddetail.asp?prod=SM-BOLT-70B
[Re: Mass_Mopar]
#1444178
05/29/13 02:53 PM
05/29/13 02:53 PM
Posts: 75,058 U.S.S.A.
JohnRR
U.S.S.A.
Yes that is it BUT is your handle a slip in , original 70 will be , or a bolt on like the one in the picture ?
Talk to Brewer and make sure you get it the right way , or I think you can drill your handle and make it tighter than the slip in .
[Re: JohnRR]
#1444179
05/29/13 03:28 PM
05/29/13 03:28 PM
Posts: 5,867 MA
Mass_Mopar
MA
Mine's a slip-in but I always thought it was dumb. I'll have no problem drilling & bolting. Thanks John
