Page 1 of 5 1 2 3 4 5
1941 Dodge truck project #1443091
05/27/13 09:45 PM
05/27/13 09:45 PM
Kentucky
Flipper1938 Offline OP
Kentucky
This is the start of a new build thread. A 1941 Dodge Truck
This thing was bought out of the HAMB classifieds in 2006 and then piled in a corner. The truck body parts and 2001 Dakota chassis came as a package deal. The wheels came off of ebay. They are 90's-2000's era Halibrands that were made for a Dakota (17x7, 18x9.5)
First mock-up pic
headlight idea....37 ford lenses and rings
the front end is way too wide. the Dakota is going to get hacked to work (wheelbase is way too long too).
I got to play with Dad's latest toy to dig it out.
This thing is a total basket case....all in pieces. I have a lot of trial and error ahead of me to make this a truck again. The floor and firewall were cut out. I have a wc-54 firewall to go back in.
Anybody got pictures of how the front cap attaches to the cab? Anybody have a link to some refernce dimensions for the cab? I'm sure this one moved some without floors and firewall.
Re: 1941 Dodge truck project [Re: Flipper1938] #1443092
05/28/13 03:08 AM
05/28/13 03:08 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
NICE PROJECT, maybe he sold it when he seen the front was to wide,, love the 37 ford headlite idea,,may be easier to widen the frotn fenders if you plan on using those kool wheels,,or maybe a different back space on the rim would get the tire inward,,,
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: 1941 Dodge truck project [Re: fstfish66] #1443093
05/28/13 07:59 AM
05/28/13 07:59 AM
Kentucky
Kentucky
I had already thought about widening the fenders. I'm not sure about adding 3 or 4 inches per side (what it would take to tuck these wheels)
Re: 1941 Dodge truck project [Re: Flipper1938] #1443094
05/28/13 01:18 PM
05/28/13 01:18 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
Hi Richard,here are some pics of a guy building a camper and look at the front fender wideners, I think they are a stock Big truck item. but you could just add 3-4" to the inside lip to widen yours...
oh and it looks like a cool project you got there...Ron.
Re: 1941 Dodge truck project [Re: Mopar Ron] #1443095
05/28/13 05:29 PM
05/28/13 05:29 PM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
Richard, something to think about on the frame. You have already noticed that the Dak frame kicks up over the axle and stays too high for a flat bed floor. I cut the Dak frame just behind the cab on my 57 and welded on the shortened, narrowed, and boxed rear section of my 57 frame. This allowed me to have the original bed and floor height.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: 1941 Dodge truck project [Re: Mopar Ron] #1443096
05/28/13 08:36 PM
05/28/13 08:36 PM
Kentucky
Kentucky
Holy crap that thing is cool!
Are those "fender spacers" dodge items? I've never seen anything like that before. I've never seen fenders exactly like those before either.
The wide look does look good.
Re: 1941 Dodge truck project [Re: rattler] #1443097
05/28/13 08:39 PM
05/28/13 08:39 PM
Kentucky
Kentucky
I didn't get a stock frame with mine.
I've been kicking around the idea that this might be a flatbed.
Re: 1941 Dodge truck project [Re: Flipper1938] #1443098
05/29/13 04:50 AM
05/29/13 04:50 AM
Arizona
cpeceo Offline
cpeceo  Offline
Arizona
The only direct attachments between the front end and the cab are 2 bolts from inside the kick panel area into the fender flange (a couple inches forward of the door hinges) and then the 2 struts from the upper cowl that go forward to near the center of the upper "nose" section. On the original frame, the upper and lower grill sections and fenders are mostly held in place to the frame with the 2 fender inner panels (the panels with the vertical louvers) and the core support. The fender inner panels bolted front and rear onto the top of the frame rails. The core support, the large u-shaped channel, had 2 bolts at the bottom center that bolted to a flange on the front edge of the main cross member.
I'm currently moving my '41 from its original frame onto a '95 Dakota chassis with a '05 5.7L HEMI. A cross-member has to be fabricated for the core support, then the inner fender panels need to be adjusted to attach to something since they are no longer directly above nor parallel to the frame rails. I think I will use some sturdy 90 degree tabs attached to the Dakota frame rails to support the inner fender panels.
While we have my '41 cab off without nose or fenders attached, I'll take some pictures and measurements. My truck has been in Cali and Arizona all it's life and 100% rust and damage free, so measurements should be reliable.
My '41 frame will be on the market soon
Re: 1941 Dodge truck project [Re: cpeceo] #1443099
05/29/13 09:28 PM
05/29/13 09:28 PM
Kentucky
Kentucky
Thanks for the info. I would love to see pictures of a solid truck.
I went to pull-a-part and looked at an earlier Dakota frame, They are prettier than the 2001 frame (don't have the bolt on section at the rear). I was disappointed to find out they were only 2.5 inches or so narrower. That wouldn't be enough for me to tuck my wheels.
Re: 1941 Dodge truck project [Re: Flipper1938] #1443100
05/30/13 10:55 PM
05/30/13 10:55 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
I suspect you will find the difference in the width of the early Dakotas compared to the later models had a lot to do with the wheel offset. The rims on the 1st gen Dakota set in from the wheel mounting surface. I'm posting a picture of my 48 Plymouth (again), look at the differences between the front wheel offset and the rear wheel offset. The fronts are 15 x 6 from a 90 Dakota, the rear wheels are 15 x 6 1/2 off a Chrysler 5th Ave. Gene
Re: 1941 Dodge truck project [Re: Flipper1938] #1443101
06/01/13 03:08 PM
06/01/13 03:08 PM
Kentucky
Kentucky
[QUOTE]
[/QUOTE]
I thought I was being unique. Turns out I was being Studebaker.
Re: 1941 Dodge truck project [Re: Flipper1938] #1443102
06/03/13 02:12 PM
06/03/13 02:12 PM
dogdays Offline
dogdays  Offline
Let's not forget Willys!
R.
Re: 1941 Dodge truck project [Re: Flipper1938] #1443103
06/07/13 03:48 AM
06/07/13 03:48 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
[QUOTE]
[/QUOTE]
37 stud pick up ?? rare bird, interesting truck,,,
still love the 37 ford head lites on your dodge,,looks classy
2015 cherokee
2013 R/T classic
Re: 1941 Dodge truck project [Re: fstfish66] #1443104
06/08/13 10:11 AM
06/08/13 10:11 AM
Kentucky
Kentucky
I think the studebaker has some neat features to copy/merge with the dodge features. Studebaker was definetly ahead of their time. That truck has a double walled bead too!
I've always looked at the peak in the dodge fenders and wished there was a way to highlight the peak even more. I looked at the headlights in the swap meet area of the Bunny Run car show and it clicked.
Re: 1941 Dodge truck project [Re: Flipper1938] #1443105
06/16/13 02:41 PM
06/16/13 02:41 PM
Kentucky
Kentucky
I've been rolling possible solutions to the front wheel placement issue (narrow suspension vs. widen fenders). Well, this wekend i saw a 39 Pontiac and studied the shapes of the front sheetmetal. Widening the Dodge fenders inside the peaks should look a little bit like the front fenders on this car.
Re: 1941 Dodge truck project [Re: cpeceo] #1443106
06/22/13 12:46 PM
06/22/13 12:46 PM
Kentucky
Kentucky
Cpeceo,
Have you had a chance to tear into your truck yet? I'd love to see pics of how this thing is supposed to go back together.
Re: 1941 Dodge truck project [Re: Flipper1938] #1443107
09/24/13 08:55 AM
09/24/13 08:55 AM
Kentucky
Kentucky
This past weekend, I played with the Dodge again. I tried the Fargo big truck front cap that was in the pile of parts I got with this truck. It fits the Dakota chassis a lot better,but I will need to fill in the wheel openings to match the smaller wheels. I need to modify the radiator bracket to get it to sit a few inches lower.
Also, I need to cut about 10 inches out of the frame and then lower the crap out of the truck (seven inches up front and five in the rear).
IMG_6048 by Flipper_1938, on Flickr
IMG_6055 by Flipper_1938, on Flickr
IMG_6066 by Flipper_1938, on Flickr
Re: 1941 Dodge truck project [Re: Flipper1938] #1443108
09/24/13 09:11 AM
09/24/13 09:11 AM
Kentucky
Kentucky
It should make a decent looking truck...
Fargo by Flipper_1938, on Flickr
Re: 1941 Dodge truck project [Re: Flipper1938] #1443109
09/24/13 09:43 AM
09/24/13 09:43 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
looks good so far,,,i agree the front wheel openings do look large
2015 cherokee
2013 R/T classic
Re: 1941 Dodge truck project [Re: Flipper1938] #1443110
10/12/13 07:44 PM
10/12/13 07:44 PM
Kentucky
Kentucky
I gave up on trying to find a cheap stand alone efi set-up for a dodge and crossed over to the dark side. I bought a 5.3 LS motor/trans/ecm and harness/gas tank/driveshaft for $900. Chevy computers are apparently way easier to crack (people will remove the anti-theft/emissions stuff and re-flash for $75) and instructions to modify the harness are online.
IMG_6248 by Flipper_1938, on Flickr
