Orange ECU box failure #1443021
05/27/13 06:21 PM
05/27/13 06:21 PM
Sec.414,seat 12,White Sox Park
swapman Offline OP
swapman  Offline OP
Tried starting Cuda for first time this year. No spark.
Checked for power everywhere. Put in a friends new ECU box and it started and ran perfect.
My question to all is this... I hid the box under battery tray.
When I changed it, the screw that holds the harness on was missing.
Could vibrations from a loose harness cause the box to fail? Or was it most likely a coincidence.
Anyone have this happen to them?
Another fifty bucks to replace.
Re: Orange ECU box failure [Re: swapman] #1443022
05/27/13 06:26 PM
05/27/13 06:26 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
most likely crappy chinese made part or lack of good grounds.
Re: Orange ECU box failure [Re: swapman] #1443023
05/27/13 06:37 PM
05/27/13 06:37 PM
There's been a fair number of reported orange box failures esoecially the newer crop but not all of em & we only get the bad reports since we are here to solve problems. Even tho electronic devices dont respond favorly to an open circuit I would think an open would just stop it from functioning rather than burning it out & those pentastar connectors tend to fit pretty tight even without the holddown screw. I just bought a Standard Motor Products LX101 4 pin ECU which is the old reliable standby & guess what it is now made in china so I bought 2 of em . My FBO coil (older not his new full 12V one)& MP .25 ohm ballast & after a year or so the OE black ECU died so I have the lx on there & a spare in the trunk). it (DD 318) starts instantly year round & that tells me that the ign is compatible & Jacobs ign' came up with something which is that there are different ign requirements for starting/cruising/wot & too much ign can actually cavitate the plug gap & drive air/fuel molecules out & makes things worse & I just stopped at that point
Re: Orange ECU box failure [Re: RapidRobert] #1443024
05/27/13 06:50 PM
05/27/13 06:50 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
50 bucks for what ?? Another pos "orange" box ??
I am truckless..
Re: Orange ECU box failure [Re: 340SHORTY] #1443025
05/28/13 11:03 AM
05/28/13 11:03 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I agree , swapman , don't buy another orange box , it did you a favor by crapping out. either get a revanator or buy the 7500 rpm box off ebooger on ebay.
PM me your address , i'll send you an orange box to keep you going till you decide on what to buy .
Re: Orange ECU box failure [Re: JohnRR] #1443026
05/28/13 11:36 AM
05/28/13 11:36 AM
swapman Offline OP
swapman  Offline OP
Okay okay. You guys don't have to hit me over the head more than twice.
I listen to the wise words of MOPARTS. Just ordered two from EBOOGER on E-Bay.
One for me and one for a spare.
Thanks to all. Really appreciated.
Re: Orange ECU box failure [Re: swapman] #1443027
05/28/13 01:44 PM
05/28/13 01:44 PM
dogdays Offline
dogdays  Offline
Meanwhile my $40 ebay MSD6 keeps on keepin' on. Just how much of the Kool-Aid have you guys drunk? I am constantly amazed at what you'll go through just to keep that MOPAR electronic ignition that's "good enough" and was so groundbreaking back in '73.
R.
Re: Orange ECU box failure [Re: dogdays] #1443028
05/28/13 02:00 PM
05/28/13 02:00 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
R.
Re: Orange ECU box failure [Re: JohnRR] #1443029
05/28/13 08:54 PM
05/28/13 08:54 PM
MICHIGAN
BB65Barracuda Offline
MICHIGAN
I run a Revanator on my 66 426 Hemi!!
Works Better than my old MSD6AL Cost around 200.00 delivered and goes right where your old Orange box went with no wiring changes.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: Orange ECU box failure [Re: BB65Barracuda] #1443030
05/28/13 11:19 PM
05/28/13 11:19 PM
P
Paul_Fancsali Offline
P
I have at least 12 mopar control boxes The ones I trust are the factory 4 pin ecu, that were used in late 80sI also have several new orange / chrome boxes they will stay in drawer. After fighting no start issues every spring I finally switched to either points or pertronix they don't let me down and frankly they are so easy to work with that I won't switch back
Re: Orange ECU box failure [Re: swapman] #1443031
05/29/13 01:34 AM
05/29/13 01:34 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I quit using the Mopar ignitions 20+ years ago when they doubled in price and the quality went to !%@#.
I had an older orange box and gave it to a friend when his box went out at the track. I use CD ignition boxes now, MSD (6 and digital 6) and Crane HI-6.
Re: Orange ECU box failure [Re: 451Mopar] #1443032
05/29/13 02:00 AM
05/29/13 02:00 AM
dogdays Offline
dogdays  Offline
I'd like to see a real third party test on a 300 hp engine and a 550 hp engine using the RevNnator and competing MSD, Crane, and my favorite Accel 300+.
Years ago when Circle Track did a test the results were very close and probably within test error. of course, that was several years ago.
R.
Re: Orange ECU box failure [Re: dogdays] #1443033
05/29/13 09:04 AM
05/29/13 09:04 AM
MICHIGAN
MICHIGAN
R.
I'll admit I was skeptical about the Revanator until I saw Dave Dudek in Detroit tested it out and had actual HP gains on one of his cars.
I've used MSD exclusively for years and never had a failure.
The Revanator was a bolt in on the wifs car instead of finding a place to hide the box and the additional wiring.
I dont want to get out the pom poms but I bought the RTGarage Revanator ignition and it works great.
Re: Orange ECU box failure [Re: BB65Barracuda] #1443034
05/29/13 10:17 AM
05/29/13 10:17 AM
SE PA
Yellow Fever Offline
SE PA
Re: Orange ECU box failure [Re: Yellow Fever] #1443035
05/29/13 01:40 PM
05/29/13 01:40 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
for 200 bucks it had better be better
Re: Orange ECU box failure [Re: 05dakota] #1443036
05/29/13 02:37 PM
05/29/13 02:37 PM
dogdays Offline
dogdays  Offline
Here's their published average data:
Vs. orange box on a 340...12hp, 14 lb-ft
vs. MSD 7AL on a 440...0.5hp, 1.3 lb-ft
Vs. MSD 6AL on a 493....2.7hp, 3.4 lb-ft
So, my conclusion is: Versus the orange box the RNnator didn't retard spark at higher rpm and made 6% more power.
Versus MSD 6AL increase of 2.7hp, 3.4lb-ft +0.45%
Versus MSD7AL, increase of 0.5hp, 1.3lb-ft +0.082%
So where's the 10-40 hp gain? That's the advertising claim. Against the real competition the gains were within measurement error. Against the real competition, the gains were less than 1/2 of a percent, measurement error.
Advertising claims are NOT BACKED UP BY THEIR OWN DATA!
Another thing...advertised "re-engineered with new digital technology." Shoot, I'm making this post with digital technology.
Don't get me wrong, I am all for anyone who makes a better product in the USA, especially for Chrysler products. It appears that the orange or chrome box has been bettered. But let's not be misleading.
R.
