I normally dont use my chute but the 1 time I needed
it I didnt pull the safety pin... luckily I was only
running 1/8 mile that day but I stayed in it well
past the 1/8 marker... on the starting line I dumped
the trans button and heard a LOUD boom but the car
was running fine... when I hit the brakes I was doing
about 125 mph... the pedal went farther than normal...
I hit it again and it went to the floor... I went for the
chute to get nothing... the lever went forward but
no chute... I started zig zagging down the track and
the other driver seen there was something going on and
I was taking both lanes and down shifted into 2nd
but I was doing about 30 mph on the last turn around
(its a TIGHT 180)... I seen a couple people standing
just up the return road so I hit the grass
and spun it out and stopped.... the rear caliper mount
busted off and got rapped around the axle and tore
the break lines off.... now I dont even put the safety
pin in it at all
