Re: Rear disc brakes - Cobra kit from Dr Diff
[Re: DoctorDiff]
#1441602
05/31/13 04:22 PM
05/31/13 04:22 PM
Posts: 6,516 Santa Cruz, California
Lefty
I make 2 different versions.
The 10.7" kit uses Toyota Cressida rear rotors.
The 11.7" kit uses Mustang Cobra rear rotors.
I recommend the 10.7" kit for 15" wheels and the 11.7" kit for 17" and larger wheels.
FYI the 11.7" Cobra kit fit a 15" American Racing. Just barely... The wheels and tires are being replaced with much better rubber and custom offset wheels to stuff as much tire as possible underneath and still fit the stock wheel wells. I'm shooting for a 305/45 in the rear and 275/45 in front. We'll see...
[Re: BigSugar]
#1441604
06/01/13 09:18 PM
06/01/13 09:18 PM
Lefty
I'm running the Viper front setup as well. Manual with a 15/16 master. Works well. Great pedal.
That's how I build them too (manual - no booster, 15/16" MC piston). I like having the same pedal feel with the engine on or off and at any rpm.
[Re: Lefty]
#1441605
10/23/13 09:01 PM
10/23/13 09:01 PM
Posts: 2,432 NorCal
RylisPro
NorCal
Does anyone have tips on how to install the Dr Diff 11.75 brakes? I got my kit and am going to install it but I have never pulled the axles or swapped to rear dics before I am sure it is not rocket science and should not be too hard, just wondering on the torque specs on the bolts used, etc. I have seen instructions on other brands of rear brake kits but not Dr. Diff's http://www.tsmmfg.com/2160.htmlhttp://www.moparts.org/Tech/Archive/brake/8.htmlthanks
[Re: RylisPro]
#1441606
10/23/13 10:42 PM
10/23/13 10:42 PM
Posts: 1,491 Lethbridge, AB, Canada
dangina
I have seen instructions on other brands of rear brake kits but not Dr. Diff's http://www.tsmmfg.com/2160.html http://www.moparts.org/Tech/Archive/brake/8.html
thanks
do you need tips on just installing the kit or do you need to know how to replace the timken bearings, wheel studs ect ect?
[Re: dangina]
#1441607
10/23/13 11:30 PM
10/23/13 11:30 PM
Posts: 2,432 NorCal
RylisPro
NorCal
I need to know how to replace bearings, wheel studs, etc etc...
