Re: Hard Brake Pedal
[Re: JT01]
#1441491
05/24/13 10:16 PM
05/24/13 10:16 PM
RapidRobert
I'd check how much clearance you have between the rounded nub on the end of the pushrod coming out of the booster & the bottom of the M/C rear piston (thimble). Want ~.060" or a bit less. Might crack a corner bleeder (either side) on the front then on the rear (seperately) & see if you get a full stroke. Might work the pedal & have a helper see how the front calipers are acting & might take off the rear drums & same deal but just a moderate amt of pedal travel when the rear drums are off so he dont pop the rear wheel cyl pistons out
[Re: a493demon]
#1441494
05/25/13 10:07 AM
05/25/13 10:07 AM
Posts: 29 Ohio
JT01
Ohio
if you take off the master cyl. from the booster the rod should be adjustable , the rod might be adj. out too far try turning it in and see if that helps.
Allready did that never changed anything
[Re: DoctorDiff]
#1441498
05/25/13 08:02 PM
05/25/13 08:02 PM
Posts: 29 Ohio
JT01
Ohio
I don't think SSBC provides the correct master cylinder with their brake kits. Measure the bore size to confirm.
You need a 15/16" master for a '73-'75 A-body power disc brake application. [/quote. Where can I get one of these master cylinders and is it a 2 bolt application
[Re: JT01]
#1441499
05/25/13 08:21 PM
05/25/13 08:21 PM
RapidRobert
An 89 Dakota 15/16" M/C would be a 2 bolt app. The 73-75 A body 15/16" app would not
[Re: JT01]
#1441500
05/25/13 08:30 PM
05/25/13 08:30 PM
Posts: 26,017 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Be sure the booster pushrod isn't preventing the rear piston in the MC from fully returning. If the pushrod is adjusted out too far the rear piston won't allow the fluid to return to the reservoir and you'll get a hard pedal.
[Re: John_Kunkel]
#1441501
05/25/13 08:58 PM
05/25/13 08:58 PM
Posts: 29 Ohio
JT01
Ohio
We adjusted the pushrod all the way in and it still has a hard pedal
[Re: RapidRobert]
#1441502
05/25/13 09:06 PM
05/25/13 09:06 PM
Posts: 29 Ohio
JT01
Ohio
Would this M/C have the lines going in on the drivers side
[Re: JT01]
#1441503
05/25/13 09:08 PM
05/25/13 09:08 PM
RapidRobert
I would think so but I'm not sure. I'd have your parts house pull it off the shelf & let you know
