Does computer know what octane you're running? #1441212
05/24/13 01:46 AM
05/24/13 01:46 AM
NW Ohio
6pkaar Offline OP
6pkaar  Offline OP
NW Ohio
OK, it's my Buick Enclave, but I have a question. I stopped for gas a couple days ago and the station only had premium (selling at regular price). I filled up and had problems starting the car.... it wouldn't pop right off as usual, after it started everything was OK. This would happen about 75% of the time. I have since used that tank and back to regular gas and it starts right up. Does the computer "know" what octane you're using and try to retune the engine? That tank of gas was the only time it acted up in 80,000 plus miles.
Re: Does computer know what octane you're running? [Re: 6pkaar] #1441213
05/24/13 02:01 AM
05/24/13 02:01 AM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
In your case, I doubt the fresh gas would have instantly been in the injectors at the start. I'm guessing that you didn't coast in there totally empty, right?
Re: Does computer know what octane you're running? [Re: Jjs72D] #1441214
05/24/13 02:06 AM
05/24/13 02:06 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Higher octane fuel lights off at a higher temperature. This could explain the difference...
Re: Does computer know what octane you're running? [Re: Jim_Lusk] #1441215
05/24/13 11:32 AM
05/24/13 11:32 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
The computer has short and long term fuel trim (tweaks to the original fuel mapping that are unique to your car).
It also should have knock sensors that often are used to optimize timing curves that would be more likely to be affected by octane. It doesn't "know" it's different gas, just that it is more resistant to detonation.
I'd guess that it's as said, just slightly harder to light off.
May also be a warning to do a fuel filter if it's got a bunch of miles on it.
Re: Does computer know what octane you're running? [Re: RodStRace] #1441216
05/24/13 07:35 PM
05/24/13 07:35 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Today's gas goes stale quicker than it did. Might have been a tankful of stale gas they were getting rid of with a story.
You could try another tankful of premium from another source to see.
Don't be the exception.
Re: Does computer know what octane you're running? [Re: Supercuda] #1441217
05/24/13 10:32 PM
05/24/13 10:32 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
My '97 Mustang GT runs on anything, but its computer adjusts timing for detonation. Seems a bit perkier on 92 than 87, but never had a problem starting it.
Re: Does computer know what octane you're running? [Re: topside] #1441218
05/25/13 02:24 AM
05/25/13 02:24 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I'm not aware of sensors that read octane, but there must be SOMETHING that the computer reads to know the difference in E10 and E85 to automatically adjust the tune. Supposedly "perfect stoich" of ethanol is not 14.7:1 like regular gas so the computer can't read JUST the O2 sensors, can it?
And not all cars have knock sensors...
I'd guess it was just a tank of bad gas. Want to test your theory? Get premium gas from another station... Chances of getting 2 tanks of bad gas from 2 different stores "back to back" is very slim.
**Photobucket sucks**
Re: Does computer know what octane you're running? [Re: 70Cuda383] #1441219
05/25/13 10:43 AM
05/25/13 10:43 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yeah, I should have said detonation, and I've edited that.
Re: Does computer know what octane you're running? [Re: 70Cuda383] #1441220
05/25/13 11:19 AM
05/25/13 11:19 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Tom,
Fuel sensors are on every flex fuel vehicle.
There are even DTCs for them.
P0169, P0176, P0177, P0178, P0179.
Also, since as you say the A/F ratio is different for gas, alky and any blend, when in feedback (operating temp, not WOT or decel, O2 providing results), it can 'see' that it's too rich or lean and compensate, although that's not 100% and not all the time. O2 feedback is better used to trim or adjust the programmed ratio, not make broad changes. Gasoline is 14.7:1, alky is 5.0-6.0:1.
These are by weight too!
More at http://www.smokemup.com/tech/fuels.php
Not all cars have knock sensors, but GM LOVES 'em and I guessed that any Buick Enclave (2008-present)
http://www.edmunds.com/buick/enclave/
Is going to have 'em.
Ford loves to 'test' theirs by purposely overadvancing the timing on acceleration and using the knock sensors to pull timing out.
and I agree on the bad load...
