When I purchsed my a12 in Feb., the motor was rebuilt and blueprinted but never installed in the car or fired (since 1986!). By luck, when I wrote the OK DMV, a copy of the receipt was in with the rest of the paperwork. But there are no specs. Just shows new pistons, cam, bearings, balance and head work.
Anyways, I'm going to install a Bob K. cam that I have and a set of new springs, seals, and lifters. When I pulled the heads and checked the depth of the .030 pistons, they seem to be averaging around .102 deep.
I've done an ameature check of the CC's on the heads and though they have been milled (not sure how much), I get roughly 85cc's. They are the original 906's.
So now the questions:
1) Should I use the stock MP Hemi springs or C-Cams 993?
2) I do have a new set of SS valves that will lesson the CC's since they are not concaved. Should I go ahead and do this and install hardened seats?
3)Should I use a steel head gasket, felpro blue, or ???.
4) I'd like somewhere around 9.5 compression.
5) This car won't see much racing, but I'd like to get in the high 12's. It will be completely stock, except Bobs cam. Which is near stock and legal.
Back to top
