Page 1 of 3 1 2 3
DNF'd at the Silver State Classic NOW WITH VIDEO! #1439891
05/21/13 03:29 PM
05/21/13 03:29 PM
Erda, UT
67Charger Offline OP
Erda, UT
Made it about 34 miles in the Silver state when "BRAP BRAP BRAP BRAP...." happened at 4700 rpm doing about 137.
It sounded like I popped a spark plug, but it was too loud and it was still firing. It later guessed a broken valve spring on an intake, allowing the valve to drop, hit the piston and get jammed up in the guide, allowing the combustion to backfire through the manifold. Wrong again. It is time to retire the Crane Golds. The adjuster was there and set correctly, but was loose. The rocker wash pushed off the shaft high enough that the lift from the pushrod was no longer hitting it.
I run about .640 lift and 400 - 430# open spring pressure on these 1.6's
Video of the end of my run...
NORC 2013
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: DNF'd at the Silver State Classic [Re: 67Charger] #1439892
05/21/13 04:00 PM
05/21/13 04:00 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
It sounded like I pospped a spark plug, but it was too loudm it was still firing. It later guessed a broken valve spring on an intake, allowing the valve to drop, hit the piston and get jammed up in the guide, allowing the combustion to backfire through the manifold. Wrong. It is time to retire the Crane Golds. The adjuster was there and set correctly, but was loose.
Sorry about your troubles.
1.5s will last much longer, be much more stable and oil better, less chance of burning up the adjuster. Don't blame the rockers. Blame the adjusters and the ratio,imo.
Re: DNF'd at the Silver State Classic [Re: Challenger 1] #1439893
05/21/13 05:20 PM
05/21/13 05:20 PM
Erda, UT
Erda, UT
Those are Smith Brothers adjusters and pushrods, and both are still in perfect condition. The adjuster had not backed out at all. The threads were beaten in the rocker, allowing me to twist the screw out by hand. The point of failure was overheat at the shaft to the point of weakening the aluminum and allowing the bottom to stretch apart and fracture. The rocker was so hot it was burning the oil spray. Notice the adjacent rockers are clean. I would say looks as if it ingested some debris and blocked the oil passage. I'll know more when I get it apart tonight. The discoloration on the end of the pushrod is burnt oil, not metal bluing.
Re: DNF'd at the Silver State Classic [Re: 67Charger] #1439894
05/21/13 05:46 PM
05/21/13 05:46 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
HERE is a testament for more oil UP ON the top end of the motor. I will bet that if you tested the valve springs ... they would be "hurtin'" too ...
Re: DNF'd at the Silver State Classic [Re: Challenger 1] #1439895
05/21/13 05:50 PM
05/21/13 05:50 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I don't know, I don't trust unbushed alum rockers on steel.
What are those rockers rated for for open spring pressure ?
OP are your shafts banana groove ? If it was getting hot enough to burn up the oil it was on it's way to siezing on the shaft , I bet it's not the only one you will find with some damage. How close is that one to the oil hole that feeds the shaft?
Re: DNF'd at the Silver State Classic [Re: JohnRR] #1439896
05/21/13 06:45 PM
05/21/13 06:45 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
There are lots things that could cause that but without more info its hard to say for sure.
Are they Edelbrock heads? If so new or used
Crane shafts have a right and a wrong way for install for proper oiling. Harlan Sharp can go on either way.
Like asked above were the shafts banana grooved?
If so were they done right. Some guys make the grooves to long and the oil sneaks out past the rocker.
Did you limit the oil going to the head. Some guys do.
Were the rockers shimmed right side to side?
Were the rockers checked for proper sweep on the valve tip.
How many runs did the rockers have on them?
I personally never use those springs as they do not limit rocker placement properly. I usually take 3-4 hours setting up rockers the right way.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: DNF'd at the Silver State Classic [Re: pittsburghracer] #1439897
05/21/13 08:42 PM
05/21/13 08:42 PM
Erda, UT
Erda, UT
Your answers, in order:
Are they Edelbrock heads? -Yes, RPM's
If so new or used? -I purchased them new, 6 years on them now.
Crane shafts have a right and a wrong way for install for proper oiling. Harlan Sharp can go on either way. -Definitely on on the correct orientation
Like asked above were the shafts banana grooved? -No
If so were they done right. Some guys make the grooves to long and the oil sneaks out past the rocker. -Again, not grooved
Did you limit the oil going to the head. Some guys do. -No
Were the rockers shimmed right side to side? - springs between them with steel rings for wear protection
Were the rockers checked for proper sweep on the valve tip. -perfectly across the center
How many runs did the rockers have on them? -a few hundred and 1500 miles of standard driving and road racing
Re: DNF'd at the Silver State Classic [Re: 67Charger] #1439898
05/21/13 09:14 PM
05/21/13 09:14 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Sorry to hear about your mechanical trouble. On another subject, did you see Joel Hanning running his 62' Polara there? Dave
Re: DNF'd at the Silver State Classic [Re: quickd100] #1439899
05/21/13 09:19 PM
05/21/13 09:19 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Sorry to see your troubles Dan
I'll be looking forward to viewing the other rockers and shafts. Going to take a wild guess, with that low mileage on them, some sort of oiling issue
Re: DNF'd at the Silver State Classic [Re: 67Charger] #1439900
05/21/13 09:19 PM
05/21/13 09:19 PM
PA.
"Little"John
"Little"John
PA.
I google search on Crane rockers and there instructions said the big block rockers came with springs and their small block rockers used the aluminum spacers. Not sure way but maybe to stabilize at higher rpm's. Hard to tell if yours are big block or small block from that picture but here are their small block instructions.
http://www.cranecams.com/uploads/instructions/198e_.pdf
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: DNF'd at the Silver State Classic [Re: pittsburghracer] #1439901
05/21/13 09:22 PM
05/21/13 09:22 PM
PA.
"Little"John
"Little"John
PA.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: DNF'd at the Silver State Classic [Re: pittsburghracer] #1439902
05/21/13 09:25 PM
05/21/13 09:25 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Oh, and I agree with pittspukeracer on using spacers instead of springs between the rockers
Re: DNF'd at the Silver State Classic [Re: roadhazard] #1439903
05/21/13 09:47 PM
05/21/13 09:47 PM
PA.
"Little"John
"Little"John
PA.
Pittspukeracer.???????????????????
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: DNF'd at the Silver State Classic [Re: pittsburghracer] #1439904
05/21/13 09:57 PM
05/21/13 09:57 PM
Florida STAYcation
dOc … Offline
dOc …  Offline
Florida STAYcation
DATS even bester than BURGHer guy ....
Re: DNF'd at the Silver State Classic [Re: 67Charger] #1439905
05/21/13 10:19 PM
05/21/13 10:19 PM
AndyF Offline
AndyF  Offline
Too bad RAS isn't making their investment cast steel rocker arms anymore. Those are the ones you need for an open course setup like that. The aluminum rocker arms are okay for drag racing, but your application I'd use a steel rocker arm with a bronze bushing. You might want to add some valve spring oilers also. An engine like that needs to be built like a boat motor, or a circle track setup.
Re: DNF'd at the Silver State Classic [Re: dOc …] #1439906
05/21/13 11:21 PM
05/21/13 11:21 PM
PA.
"Little"John
"Little"John
PA.
You guys are hurting my feeling.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: DNF'd at the Silver State Classic [Re: pittsburghracer] #1439907
05/22/13 10:13 AM
05/22/13 10:13 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Well, being from Cleveland my computer automatically corrects the spelling of your city
Nothing personal
Re: DNF'd at the Silver State Classic [Re: roadhazard] #1439908
05/22/13 10:39 AM
05/22/13 10:39 AM
PA.
"Little"John
"Little"John
PA.
Nothing personal
No problem and I understand. I have a different problem with my computer. Picture over-load. It spits them out all by itself.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: DNF'd at the Silver State Classic [Re: Challenger 1] #1439909
05/22/13 11:05 AM
05/22/13 11:05 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Nascar is running 2.2 ratio rockers at over 9k rpm. Has nothing to do with rocker ratio and everything to do with cam lobe, proper setup and quality parts. Crane golds are not very good rockers in my opinion, and that's why I think it's a good idea to save up for T&D or Jesel rockers. Again, just my opinion.
Re: DNF'd at the Silver State Classic [Re: pittsburghracer] #1439910
05/22/13 11:08 AM
05/22/13 11:08 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Nothing personal
I like that
Page 1 of 3 1 2 3
