Re: B series van/motorhome engine removal [Re: magnum440d100] #1439878
05/22/13 04:35 PM
05/22/13 04:35 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Trans can come out with it (just make sure the lift can handle it. )
Pull the intake so the lift arm clears the top of cowl and the oil pan clears the crossmember.
I pull everything in ft of the motor including the bumper. It just makes it easier and gets everything out of the way .
I just gave quote 3 weeks ago to do this very job.
Estimate was to pull and replace the long block with a reman. rebuild the trans while it was out - APPROXIMATE parts and labor $3500 - $4000
Re: B series van/motorhome engine removal [Re: gtx6970] #1439879
05/23/13 01:56 AM
05/23/13 01:56 AM
Sarcoxie, MO, USA
MoPar Jamie Offline
MoPar Jamie  Offline
Sarcoxie, MO, USA
okay on 71-77 Vans you CAN remove it out the pass. door. I have done two that way, one a 440, the other a 360. I took the front of the motor off both when I did it. Also I dropped both trannies.
When I parted my rotted 94 recently I pulled it out the front. but left the 518 in place (waited till the motor was out to drop it). I raised it on jackstands and used my buddies picker for it.
Because it was rotted I pulled the front end stuff and the bumper (bumper was nice so I saved it.) and I cut out the lower radiator support. I did have to pull apart the front of the motor and pull the beer-barrel intake. I didnt have to pull the manifolds or anything.
- MoPar Jamie
1972 Fury III 4dr
1986 D-150 LWB Royal SE
Re: B series van/motorhome engine removal [Re: MagnumGT] #1439880
05/23/13 05:17 AM
05/23/13 05:17 AM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Well my first time I had THE BUMPER OFF because I left the INTAKE ON... I got better at it and now my van can rough idle on race gas right with those LITTLE HAMSTER POWERED RICERS...
front wheel drive right?
Re: B series van/motorhome engine removal [Re: Bill MeLater] #1439881
05/23/13 01:16 PM
05/23/13 01:16 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
High volume pump is a waste.
I have swapped engines in my '79 twice. Raised the van, no exhaust manifolds, no intake. Grille, bumper, and the sheet metal by the bumper came off.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: B series van/motorhome engine removal [Re: Rug_Trucker] #1439882
05/23/13 01:22 PM
05/23/13 01:22 PM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
...another thought about pulling the motor out-the-front without removing everything off the front of the body .... is to pull the oil-pan and pickup .... that Xtra 6-7 inches would help in the EZier removal ...
Re: B series van/motorhome engine removal [Re: magnum440d100] #1439883
05/23/13 08:48 PM
05/23/13 08:48 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
I just did mine this winter and out the door is soo much easier
mainly not having to work the oil pan over the crossmember. Drop the
trans, pull the pass seat and have at it.
Re: B series van/motorhome engine removal [Re: Dan Halen] #1439884
05/23/13 11:28 PM
05/23/13 11:28 PM
N
NITROUSN Offline
NITROUSN  Offline
N
We did it that way all the time. This includes new vans still under warranty. Tranny comes off easy, pull the manifold and out she comes.
Re: B series van/motorhome engine removal [Re: Dan Halen] #1439885
05/24/13 07:47 AM
05/24/13 07:47 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
That picture reminds of what the motorhome looked like and the vans I used to work on. Why not out the door, why would you go out the front on that model? It was easy to work on also, everything is right there easy to get to.
