Re: B series van/motorhome engine removal
[Re: gtx6970]
#1439879
05/23/13 01:56 AM
05/23/13 01:56 AM
Posts: 4,576 Sarcoxie, MO, USA
MoPar Jamie
Sarcoxie, MO, USA
okay on 71-77 Vans you CAN remove it out the pass. door. I have done two that way, one a 440, the other a 360. I took the front of the motor off both when I did it. Also I dropped both trannies.
When I parted my rotted 94 recently I pulled it out the front. but left the 518 in place (waited till the motor was out to drop it). I raised it on jackstands and used my buddies picker for it.
Because it was rotted I pulled the front end stuff and the bumper (bumper was nice so I saved it.) and I cut out the lower radiator support. I did have to pull apart the front of the motor and pull the beer-barrel intake. I didnt have to pull the manifolds or anything.
- MoPar Jamie
1972 Fury III 4dr 1986 D-150 LWB Royal SE
[Re: MagnumGT]
#1439880
05/23/13 05:17 AM
05/23/13 05:17 AM
Posts: 671 Wisconsin USA
Bill MeLater
Wisconsin USA
Well my first time I had THE BUMPER OFF because I left the INTAKE ON... I got better at it and now my van can rough idle on race gas right with those LITTLE HAMSTER POWERED RICERS...
front wheel drive right?
[Re: Bill MeLater]
#1439881
05/23/13 01:16 PM
05/23/13 01:16 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
High volume pump is a waste.
I have swapped engines in my '79 twice. Raised the van, no exhaust manifolds, no intake. Grille, bumper, and the sheet metal by the bumper came off.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: magnum440d100]
#1439883
05/23/13 08:48 PM
05/23/13 08:48 PM
Posts: 1,650 Harm City Md.
Dan Halen
Harm City Md.
I just did mine this winter and out the door is soo much easier mainly not having to work the oil pan over the crossmember. Drop the trans, pull the pass seat and have at it. ![](http://i897.photobucket.com/albums/ac172/streetvandan/Streetvan/052-1.jpg)
[Re: Dan Halen]
#1439884
05/23/13 11:28 PM
05/23/13 11:28 PM
Posts: 18,428 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
We did it that way all the time. This includes new vans still under warranty. Tranny comes off easy, pull the manifold and out she comes.
[Re: Dan Halen]
#1439885
05/24/13 07:47 AM
05/24/13 07:47 AM
Challenger 1
Cincinnati, Ohio
That picture reminds of what the motorhome looked like and the vans I used to work on. Why not out the door, why would you go out the front on that model? It was easy to work on also, everything is right there easy to get to.
