Guess my Horsepower! #1439769
05/21/13 04:17 AM
05/21/13 04:17 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
So am hoping to get some estimates on power for my streetable 572 Hemi. Its 9.5-1, .628/.648 242@.050 cam, 112 lsa, stage5 intake with a pair of quickfuel 770s and stageV heads with the attached flow numbers. I am guessing around 640-660ish. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Guess my Horsepower! [Re: astjp2] #1439770
05/21/13 05:02 AM
05/21/13 05:02 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
720 with a good tune and fuel.
Mopar to the bone!!!
Re: Guess my Horsepower! [Re: astjp2] #1439771
05/21/13 08:21 AM
05/21/13 08:21 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If you even had 1.2 HP per ci thats 680 hp... 1.3 is
about 745hp.... at 1.2 which is pretty easy to make
you should be looking at 680
Re: Guess my Horsepower! [Re: MR_P_BODY] #1439772
05/21/13 11:04 AM
05/21/13 11:04 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
The only good thing about this motor having low compression is the fact that I can refill anywhere, we have 85 octane in the mountains so with that low of compression, it should run fine. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Guess my Horsepower! [Re: astjp2] #1439773
05/21/13 11:17 AM
05/21/13 11:17 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
680-ish with wall to wall mega-torque.
Flows through .600 are about equivalent to my Chapman Max wedges on my 517, with that little High torque broomstick cam and 572 cubes you're gonna have a hard time hooking up when you lay into it!
The thing about really good flowing heads is that even with a small cam the power/RPM doesn't fall off nearly as severely past the peak as most people might think they might
WIZE
In Car:
Re: Guess my Horsepower! [Re: Streetwize] #1439774
05/21/13 03:39 PM
05/21/13 03:39 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
I thought about having Tim Banning CNC them but then reality check said why? I have more power than I will ever use, even for the occasional trip to the track. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Guess my Horsepower! [Re: 72Swinger] #1439775
05/22/13 06:01 PM
05/22/13 06:01 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
What do you think would get me there? I have a LM1 for getting the carbs dialed in...what else can I do?
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
