I just put it my new distributor set up by FBO for my combo. I set the initial at 18 and with mechanical all in at 3200 rpm. It's a total of 34 degrees. (FBO recommended) I didn't have time to hook up vacuum advance when I was back home last time. So I was just trying to see where it should be at when I hook it up. If I remember right it is set for another 14 degrees with the vacuum advance hooked up. (the sheet is at home) Manifold vacuum was right at 10 at idle. Thanks
