Help with Drive Line Vibration #1439434
05/20/13 12:06 PM
05/20/13 12:06 PM
Wisconsin
Mopar_Mudder Offline OP
Wisconsin
I know I have read some post on firuring out what you need to change for pinion angle to fix vibration but I can't find it.
I have a TKO-600 in a 1971 Cuda. For initial set-up I have the tranny at 3-1/4 deg down the the pnion at 0
I have no vibration going down the road until about 70mph.
I have no vibration under decel
I don't think thier is any vibe under hard accell, but it is hard to tell as the power coming out of the Hemi seems a little violent making vibrations hard to pick out.
What I do have is a pretty good vibration when I push the clutch in and coast down the road. The same vibration when going down a hill and off the gas. Aslong as their is back pressure on the drive line it is gone.
I was going to get some shims to turn the pinion, any good guess on which way to go.
1971 Hemi Cuda 2005 SRT-10 Regular Cab Flame Red. 12.771 @ 109.67<---TIME SLIP--Video
Re: Help with Drive Line Vibration [Re: Mopar_Mudder] #1439435
05/20/13 12:45 PM
05/20/13 12:45 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
This from the tech archives might help.The tech Archives are a great place to get info. http://www.moparts.org/Tech/Archive/rearsusp/13.html
Re: Help with Drive Line Vibration [Re: Mopar_Mudder] #1439436
05/20/13 04:09 PM
05/20/13 04:09 PM
From prior posts I gathered if the trans is 3 &3/4 deg down then you want the pinion 3&3/4 up then lower it ~2 deg from there as the pinion will climb on accel so that'd be 1&3/4 up on the pinion. Maybe the trans being 3&3/4 down is too much to start with & it needs to be raised some for a starting point . I'd wait for the Doc or someone that knows what they're doing to chime in. I had a 1/2 ton 77 dodge pickup used for hauling that would vibrate on decell ONLY when extremely loaded down with debris so yes it was the pinion angle that was changed from the spring load. 8&1/4 iirc. EDIT I reread your post & it might actually be the gearset
Re: Help with Drive Line Vibration [Re: Mopar_Mudder] #1439437
05/20/13 08:45 PM
05/20/13 08:45 PM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
never mind what the trans is doing...level the driveline to zero at ride height...then set the pinion at 6-8 degrees nose down for leaf springs.
Re: Help with Drive Line Vibration [Re: Mopar_Mudder] #1439438
05/20/13 09:55 PM
05/20/13 09:55 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Generally the pinion rotates upward on acceleration anywhere from 2-4 degrees, with your pinion currently at 0, your dialed-in pretty close in your static "set-up", but seeing that your experiencing vibration in the DE-acceleration/coast mode, that indicates the pinion isn't rotating upward enough, buy the MP axle shim kit, add 1 to 2 degrees, rotating the pinion upward, your current spring set up may not allow the housing the rotation and or U joint phasing it needs to cancel out vibration,....FYI just make sure the pinion snubber isn't affecting the housing rotation....esp if the vehicle is lowered
Mike
Re: Help with Drive Line Vibration [Re: Mopar_Mudder] #1439439
05/21/13 06:32 AM
05/21/13 06:32 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Your pinion is -3 1/4 nose down relative to the engine/trans centerline. What type of rear suspension do you have?
Have you tried rotating your driveline 180 degrees and reinstalling it? Measure the runout of your axle flanges, try a different set of tires/rims and see if it changes?
Re: Help with Drive Line Vibration [Re: jbc426] #1439440
05/21/13 11:07 AM
05/21/13 11:07 AM
Wisconsin
Wisconsin
Rear suspension is all set-up as stock, now lowering of anyhting. The rear springs are from PST Suspension and are suppose to be reproductions of the original HEMI springs.
The rear axle is a new/converted truck Dana 60. Originally when I got it it was set-up with the pinion about 8 deg down but that just went against everything I know about drive lines, equal but opisite angles. I can see if for drag racing maybe but under normal driving down the road the pinion would have to rotate up 11.25 degs to equal out, that just isn't going to happen.
I haven't tried anything yet, my first though it rotate the pinion up another 2deg and see what happens. I can try swithing the drive shaft 180 also, good idea.
Re: Help with Drive Line Vibration [Re: Mopar_Mudder] #1439441
06/25/13 02:40 PM
06/25/13 02:40 PM
Wisconsin
Wisconsin
Wanted to update what I have done and where I am at.
I thought I had fixed the bad vibes. Went to start shiming the rear pinion and noticed that the rear u-joint seems loose. Well seems I had a 1350 yoke and a 7290 joint
So I got a new yoke and the vibe I had went away totally and all seemed to be fine. So I thought I was vibration free, well atleast as much as I can tell above the drone and vib of the TTI exhaust
This weekend I got out on the freeway for the first time and found out that I have a vibration starting between 65-70, up to that point it seems smooth. If you let off the gas it goes away, and pushing in the clutch it is gone.
Guess it is time to start shiming, I must be close since it doesn't start until higher speeds.
Re: Help with Drive Line Vibration [Re: Mopar_Mudder] #1439442
06/25/13 06:30 PM
06/25/13 06:30 PM
Are you saying that the 1350/7290 ain't compatible? Any possibility that the improper excessive clearance fubared the ujoint (in addition to the yoke you replaced)?
Re: Help with Drive Line Vibration [Re: RapidRobert] #1439443
06/25/13 06:50 PM
06/25/13 06:50 PM
Wisconsin
Wisconsin
I don't think so, only had about 20 miles on it that way. Was good and tight when I put it together with the correct yoke. I will double check it though when I jack it up to work on shims.
Re: Help with Drive Line Vibration [Re: Mopar_Mudder] #1439444
06/25/13 10:30 PM
06/25/13 10:30 PM
Cab_Burge Online work
Cab_Burge  Online Work
Try putting the shims(2 or 4 degrees) under the rear of the saddles welded onto the axle tubes first This subject, pinion angle and trans and driveshaft angles has been beat to death, bottom line, find out what works best on your car
Re: Help with Drive Line Vibration [Re: Cab_Burge] #1439445
06/26/13 10:13 AM
06/26/13 10:13 AM
Wisconsin
Wisconsin
Yep, thats my plan
Re: Help with Drive Line Vibration [Re: Mopar_Mudder] #1439446
08/06/13 02:07 PM
08/06/13 02:07 PM
Wisconsin
Wisconsin
Another update:
Added a 1 deg shim to the axle bringing the pinion up. Seemed to help, vibration less sever and at a little higher speed.
Added another 1 deg to the mix, vibration at a little higher speed again but still their. Now I am getting quiet a bit of vibration on hard accel also. So while moving it up seems to help at speed it is making it worse under acell.
Right now the tranny is 3.7 down, rear end is 2.5 up and the drive shaft is .5 deg going up toward the rear end.
Re: Help with Drive Line Vibration [Re: Mopar_Mudder] #1439447
08/06/13 05:21 PM
08/06/13 05:21 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Another update:
before you said the trans was 3.25 down , why is it lower?
Re: Help with Drive Line Vibration [Re: Mopar_Mudder] #1439448
08/06/13 05:22 PM
08/06/13 05:22 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
How much "end play" do you have in the drive shaft?, make sure it has at least 3/4" travel on the yoke before it bottoms on the transmission's output shaft, hard acceleration will rotate the pinion higher as spring wrap up encourages it, plus sticky tires further increases it, as well as moving the driveshaft forward, compressing it inside the tailshaft, if it's bottoming out, this can be another source of driveline vibration, not to mention component failure as well...
Mike
Re: Help with Drive Line Vibration [Re: JohnRR] #1439449
08/06/13 05:52 PM
08/06/13 05:52 PM
Wisconsin
Wisconsin
Another update:
Just a difference in how the car is sitting on stands. I didn't have it block up exactly the same as I did the first go around. The 3.25 is actually closer to a actaul angle with the car sitting level. When I did it this week end I had the car sitting a little lower in the back then the front.
Also the first measurement we with an analog swinging pointer type deal. I have a digital one now that is more acurate.
Re: Help with Drive Line Vibration [Re: DAYCLONA] #1439450
08/06/13 05:55 PM
08/06/13 05:55 PM
Wisconsin
Wisconsin
Mike
End play is fine. The drive shaft will actually hit the back of the shift linkage before it will bottom out. It is very noticable when it hit, the noise and the fact it will bump it out of gear. So I know that is not an issue.
I know the vibration under power is do to pinion wrap up, but if I lower the pinion it vibrate when driving normal.
Also forgot to mension the pinion snubber is only about 3/4" from hitting the floor, seems tight.
Sure is fun to chase these things
In my SRT-10 ram I know the pinion climbs a bunch under big power. But that thing is smooth as silk all the time. Don't know why the Cuda is so tuchy, maybe the shorter drive shaft????
Re: Help with Drive Line Vibration [Re: Mopar_Mudder] #1439451
10/28/13 11:02 AM
10/28/13 11:02 AM
Wisconsin
Wisconsin
Another Update, I did some more testing this week end.
I tried something different and shimed the pinion down 3 deg instead of up. It is exactly the same as before. Smooth up to 65-70 then is vibrates, but if you let of the gas the vibration is gone.
So just to refresh memories the tranny is 3.7 down and I have tried the pinion at
+2.5
+1.5
0
-2
-3
All seem to act exactly the same, which make no sense. Guess I need to look into get the drive shaft checked next. It might have to wait until spring.
Re: Help with Drive Line Vibration [Re: Mopar_Mudder] #1439452
10/28/13 11:12 AM
10/28/13 11:12 AM
+2.5
+1.5
0
-2
-3
& changing that angle is labor intensive, hopefully Mr Murphy will leave you be for awhile after you get this taken care of. yes I'd balance the shaft/check the ujoints/yoke
Re: Help with Drive Line Vibration [Re: Mopar_Mudder] #1439453
10/28/13 01:12 PM
10/28/13 01:12 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
+2.5
+1.5
0
-2
-3
What's the "history" of the shaft?, isn't that part of the Hurst kit...or?
