dodge dart rotisserie restoration #1439127
05/19/13 10:47 PM
05/19/13 10:47 PM
minnesota
P
president61 Offline OP
P
minnesota
getting ready to put my 1973 swinger on my rotisserie. will is be ok to attach it to the four bumper bolts holes? where i have it now?
Re: dodge dart rotisserie restoration [Re: president61] #1439128
05/19/13 11:06 PM
05/19/13 11:06 PM
Canada
demon Offline
demon  Offline
Canada
The bolts holes are fine but it looks to me like your balance point is way too low. The pivot should be almost centered in the rad opening in the front and same height in the rear.
Re: dodge dart rotisserie restoration [Re: demon] #1439129
05/19/13 11:56 PM
05/19/13 11:56 PM
SE-WI
skdmark Offline
skdmark  Offline
SE-WI
Agreed. Reconsider your balance point location.
Your car will whip around and be a bear to flip back.
Re: dodge dart rotisserie restoration [Re: demon] #1439130
05/20/13 12:18 AM
05/20/13 12:18 AM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
too! I would move the crossbar right inbetween the two bolts.
JB Rhinehart, Realist
A-Body's RULE!
Re: dodge dart rotisserie restoration [Re: president61] #1439131
05/20/13 08:31 AM
05/20/13 08:31 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Concrete blocks look scary, always use them like they are used in a building, that's the strongest way and the way there designed to be used.
Not like that
Re: dodge dart rotisserie restoration [Re: president61] #1439132
05/20/13 09:07 AM
05/20/13 09:07 AM
minnesota
P
P
minnesota
thanks for the replys. i have the front of the car exactly where i want it. I need to level the car out than re-adjust the rear, which will be bring the pivot point up. i wanted to make sure those 4 holes were adequate before I make my final adjustments. i made this rotisserie on my 67 coronet so its not quite same
Re: dodge dart rotisserie restoration [Re: Challenger 1] #1439133
05/20/13 09:09 AM
05/20/13 09:09 AM
minnesota
P
P
minnesota
Not like that
lol it won't go any higher than that on concrete blocks
Re: dodge dart rotisserie restoration [Re: president61] #1439134
05/21/13 01:54 PM
05/21/13 01:54 PM
Vicksburg, MI
coffeeman383 Offline
Vicksburg, MI
Here's how someone else did it and a link for more
http://www.rhphoto.com/rotisserie.html
Not sure what he bolted to. I always use the bumber boles front and rear.
Re: dodge dart rotisserie restoration [Re: president61] #1439135
05/21/13 02:02 PM
05/21/13 02:02 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Not like that
It may not go any higher but it can definitely go LOWER , the bottom blocks are not in the proper orientation , they can crush the way you have it .
