Re: 727 front clutch clearance?
[Re: Skeptic]
#1438951
05/19/13 05:39 PM
05/19/13 05:39 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
How many clutches. The wavy washer kinda adds some clearance I don't use it in the front clutches just the rear. on the front clutches you generally go .015 per set of frictions so I'm thinking .068 should be fine especially with a wavy washer in the mix! I'll recheck my book!
[Re: Dodgem]
#1438952
05/19/13 07:22 PM
05/19/13 07:22 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
4 clutches, I've got the A@A select snap ring set, they are flat, the thinnest one was worse didn't right down the number though.
[Re: Skeptic]
#1438955
05/21/13 05:05 PM
05/21/13 05:05 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
Going through my 727 and the front clutch clearance is only .068" The wavy washer is .051, clutches are .061 and steels are .068. Is this acceptable for a street performance car? The FSM wants .088-.106". I've done some looking online and those parts seem to be std/low thickness. The pressure plate measures .068, again seems normal. Thanks, Steve
Pressure plate is .068 ??? that's way to thin , typo ?
The factory clearance is usually on the large side. did you have any issue with it like that ?
I'd ditch the wavy snap ring for a flat ring of the same thickness.
[Re: Skeptic]
#1438956
05/21/13 06:45 PM
05/21/13 06:45 PM
Skeptic
The Pale Blue Dot
4 clutches, I've got the A@A select snap ring set, they are flat, the thinnest one was worse didn't right down the number though.- referring to the final clearance
Yes, that should read .680". I may just chuck the PP in a lathe and cut the o.d to get the correct min clearance. Thanks again, Steve
[Re: Skeptic]
#1438958
05/22/13 09:30 AM
05/22/13 09:30 AM
Dodgem
Ontario, Canada
I've seen the pressure plates turned just around the the outer edge on top to allow more clearance or even clutches just in about 3/8 on the outside on one side.
flat snap ring as said above wavy is normally on rear clutches as they are applied all the time save for reverse. performance says .015 per set of clutches
stole this from john
[Re: Skeptic]
#1438959
05/22/13 09:56 AM
05/22/13 09:56 AM
JohnRR
4 clutches, I've got the [Email]A@A[/Email] select snap ring set, they are flat, the thinnest one was worse didn't right down the number though.- referring to the final clearance
Once again, are you having an overlap issue ?
[Re: JohnRR]
#1438960
05/22/13 10:42 AM
05/22/13 10:42 AM
Skeptic
The Pale Blue Dot
It's a new rebuild never been in the car, bought the trans as a core.
[Re: Dodgem]
#1438963
05/22/13 03:31 PM
05/22/13 03:31 PM
Skeptic
The Pale Blue Dot
That looks like what I was thinking about, but I'd only cut enough to get adequate clearance- with a flat snap ring.
[Re: Skeptic]
#1438964
05/22/13 04:19 PM
05/22/13 04:19 PM
JohnRR
Positive on the .680" number. I've looked @ 2 different FSMs the '72- where I got the clearance #s I posted first, the '68 that I checked this A.M. shows a much wider range of clearances. They are both consistent in showing the wavy washer in the front drum and the flat in the rear.
the wavy washer should be in the front (direct) clutch and a flat in the rear (forward) clutch
[Re: JohnRR]
#1438965
05/22/13 05:10 PM
05/22/13 05:10 PM
Skeptic
The Pale Blue Dot
That's what I thought. I may have mis-read the 2 people that seemed to post the opposite.
[Re: Skeptic]
#1438966
05/22/13 06:54 PM
05/22/13 06:54 PM
JohnRR
No, they posted the opposite and I'm too.
