Good 8 inch converter and transbrake
#1438918
05/19/13 04:36 PM
05/19/13 04:36 PM
Posts: 35 Pismo Beach California
Green416
Looking for a trans brake and good 8 inch converter.Not trying to black list any certain brand,just was curious what has worked for you guys.Also without sounding to uninformed ![](/ubbthreads/images/graemlins/hammer.gif) ,is the trans brake as easy as just changing the valve body?I know my trans had a brake on it before I bought it,but just has a reverse manual TA in it now.Just trying to research a little before I pull the trigger.Thanks in advance for any opinions. ![](/ubbthreads/images/graemlins/thumbs.gif)
1972 Duster W-5 416 10.22@133
1970 Cuda stuck in the 80's Pro Street
Re: Good 8 inch converter and transbrake
[Re: Green416]
#1438919
05/19/13 04:46 PM
05/19/13 04:46 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I've had a T/A reverse VB brake for years... I've been very happy with it BUT its not a low band apply... I bought it well before they came out with the LBA... and I like my 8" T/A conv.. its been in my car for better than 10 years and its a 5600 stall and MOST time I launch right up on the stall(no chip) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Green416]
#1438922
05/19/13 05:30 PM
05/19/13 05:30 PM
Posts: 252 St.Louis, Mo.
mokid
St.Louis, Mo.
Looking for a trans brake and good 8 inch converter.Not trying to black list any certain brand,just was curious what has worked for you guys.Also without sounding to uninformed ,is the trans brake as easy as just changing the valve body?I know my trans had a brake on it before I bought it,but just has a reverse manual TA in it now.Just trying to research a little before I pull the trigger.Thanks in advance for any opinions.
Grinner TB is the best hands down, He invented TB I believe, I have used both TCP and Conan I like my conan
[Re: MR_P_BODY]
#1438924
05/19/13 06:10 PM
05/19/13 06:10 PM
Green416
Is the Low Band Apply a good thing to have?i know it's a big no no to let off in first with my current valve body correct?Burnout in second into high,never starting in first because of the sprag.....?Does a LBA change this?
[Re: clonestocker]
#1438925
05/19/13 06:13 PM
05/19/13 06:13 PM
Green416
I believe the trans I have now is a ProTrans,but I don't have much info on how or what's in it.I bought it from Grape Ape a few years back and it was fresh but he couldn't remember exactly what was in it.He told me to call Dave and ask,but its been awhile and I'm sure he wouldn't remember,unless he keeps files.
[Re: Green416]
#1438927
05/19/13 08:13 PM
05/19/13 08:13 PM
Posts: 11,729 Portage,michigan
B3422W5
Portage,michigan
Grinder low band apply brake.... ATI convertor, are super solid choices
[Re: Cab_Burge]
#1438929
05/19/13 08:50 PM
05/19/13 08:50 PM
Green416
Thanks for all the info ![](/ubbthreads/images/graemlins/thumbs.gif) and yeah the trans is painted just as you described.I'll look for the number tomorrow.I know Grape Ape had a brake so hopefully it has a billet drum.I remember he sold the converter separate,and switched the brake for the manual valve body.Are they (brake) easy to install?
[Re: Green416]
#1438930
05/19/13 08:58 PM
05/19/13 08:58 PM
MR_P_BODY
By the way I put a T/A J conv in my Rampage with a 518 trans... test to start in a few weeks... its a 8" behind a 416 ci and Paul said it should stall at 5000 with 500 ft lbs of torque... I have 520 ft lbs ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Green416]
#1438932
05/19/13 11:45 PM
05/19/13 11:45 PM
Posts: 197 Nor-Cal
loaderpro
Nor-Cal
8" A-1 and Griner, All the converter companys do a good job with their products. With Marv selling his interest In A-1, I would probably lean towards T/A, Those guys have been doing Mopar for a very long time. As far as the brake?! I like the Griner. It's fast, consistent and expensive but it has won me a LOT of races. As far as availibility, here are a couple of numbers: Keith @ www727 Specalists.com -219-718-3542 kfl727specialist@peoplepc.comLonnie @ wwwExtreme Automatics.com -513-898-0553 Lonnie@extremeautomatics.com
[Re: 10secGTX]
#1438937
05/20/13 02:00 AM
05/20/13 02:00 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
Got 3 Tranzact of Indy brakes in use...all working great...
so if someone invented the wheel..did cragar...weld..centerline and everyone else steal it?..lol
was the wheel patented?
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
