Re: 69 gtx body side molding install
[Re: 70moparmike]
#1438229
05/19/13 10:43 PM
05/19/13 10:43 PM
Posts: 643 southern conn
1969gtx
southern conn
HI if look on the inside of the door or fender to see the holes if that are from a gtx. I do know that the steel clip w/nut go on the back end of the door. I will look to see I think I have a 69 gtx door w/holes
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
[Re: A12]
#1438233
05/20/13 02:07 PM
05/20/13 02:07 PM
Posts: 21,546 N.E. OHIO, USA
A12
N.E. OHIO, USA
note the two close together at the front of the quarter panels on each side
And between the front of the doors and the rear edge of the front fenders:
[Re: A12]
#1438234
05/20/13 02:20 PM
05/20/13 02:20 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I have one here getting ready for paint. I can measure the door and fender holes, but I don't have the exact measurements for the quarters. Both side were replaced before the car got to me.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#1438235
05/20/13 07:39 PM
05/20/13 07:39 PM
So they are clips and not speed nuts that held them in place? Good to know as I want to try and find some better moldings for our vert since the one piece has a couple dings in it.
[Re: Silver70]
#1438237
05/21/13 02:29 AM
05/21/13 02:29 AM
A12
N.E. OHIO, USA
I would assume plastic clips except for the ends... but I don't know for sure. Something I need to find out too.
If you get them from Mike at B/E&A then you get all of the correct hardware and the correct quantity....I just used the white plastic clips because I was too lazy to remove some of the interior panels ![](/ubbthreads/images/graemlins/blush.gif)
