340 6 pack manifold old vs new #1438207
05/18/13 01:25 AM
05/18/13 01:25 AM
ontario calif
N
ns1aar Offline OP
ns1aar  Offline OP
N
ontario calif
Any changes OEM vs new
NS1AAR
Re: 340 6 pack manifold old vs new [Re: ns1aar] #1438208
05/19/13 01:31 AM
05/19/13 01:31 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Excellent question.
How about the casting number between carb bases, is it the same?
Mo' Farts
Moderated by "tbagger".
Re: 340 6 pack manifold old vs new [Re: Grizzly] #1438209
06/10/13 03:25 PM
06/10/13 03:25 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
I agree.. good question. I'm aware that some of the older OE castings had mis-aligned ports (sand casting mis-alignment is common)... horizontally... the ports would jog up/down.. and IF an intake gasket is installed which has raised embossings around the ports, and IF the raised embossing would then happen to fall inside the intake rinner ports.. guess what happens... poor intake port sealing, likley vacuum leakage at any of those ports not being sealed. Typical "performance" race intake gaskets, such as from Fel-Pro and some other companies, using fiber-only type of gaskets, don't have the problem I've described. Best solution is to install gaskets having no metal-formed embossing around the ports.
It would be great if the newer casting would have been improved so to assure the horizontal aligments would be correct.
Re: 340 6 pack manifold old vs new [Re: Mopar Mitch] #1438210
06/12/13 10:19 AM
06/12/13 10:19 AM
PNW
Danan Offline
Danan  Offline
PNW
From a visual perspective (seeing as how this is the resto forum), the new manifolds look markedly different in all areas from the originals. But the one I picked up had more material around the ports. Which was a good thing because it was easier to convert to W2 specs.
