Re: Oops!! Broken Exaust Stud [Re: dOc …] #1438193
05/18/13 01:26 PM
05/18/13 01:26 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
What penetrating oil do you guys recommend? Will wax work better? Should I do both??
Re: Oops!! Broken Exaust Stud [Re: mopowers] #1438194
05/18/13 01:32 PM
05/18/13 01:32 PM
Kirkland, Washington
Pacnorthcuda Offline
PB Blaster if you go the oil route.
Re: Oops!! Broken Exaust Stud [Re: Pacnorthcuda] #1438195
05/18/13 01:35 PM
05/18/13 01:35 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Will one one these run a drill bit? I've got one in my drawer.
Re: Oops!! Broken Exaust Stud [Re: mopowers] #1438196
05/18/13 01:52 PM
05/18/13 01:52 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Die grinders spin 12,000 rpms plus, they don't make torque.. A drill spins 300-1800 rpms & torque is what makes it work... So no the die grinder isn't a good idea.... FWIW the welding a nut method does work great, I've done it a few times & I've done recessed bolts, I think yours is borderline to deep but if your good with a welder & don't have an angle drill I think I'd give that a shot.. If you weld on it getting a drill started straight is gonna be harder for sure... But if it works you'll be saved the PITA of drilling & ez-outting the bolt..
Re: Oops!! Broken Exaust Stud [Re: 1_WILD_RT] #1438197
05/18/13 03:10 PM
05/18/13 03:10 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
I guess I'll try welding a nut first. I've already been soaking it with some PB Blaster. I'll use a washer with a small hole so I don't hit the sides of the stud hole with wire. Then I'll weld a nut to it. I'll keep you posted. If I don't respond, it means I dumped the car in the river.
Re: Oops!! Broken Exaust Stud [Re: mopowers] #1438198
05/18/13 06:10 PM
05/18/13 06:10 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
You might want to use at least a 1/4" washer so you can get some heat into the stud...
Re: Oops!! Broken Exaust Stud [Re: 1_WILD_RT] #1438199
05/18/13 07:40 PM
05/18/13 07:40 PM
McGregor,Iowa 52157
500ciDuster Online content
500ciDuster  Online Content
McGregor,Iowa 52157
I always do the nutweld treatment too but I let it cool so it isn't oversized in the hole
Mitch
Re: Oops!! Broken Exaust Stud [Re: mopowers] #1438200
05/18/13 07:47 PM
05/18/13 07:47 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
IT WORKED!!! I used a fender washer with a 3/16" hole. It welded real easy to the stud. Then I welded a 5/16" nut to it. By the time I filled the nut from the inside with weld, it was red hot. I waited until it wasn't red anymore, and it backed right out with a 1/2" wrench. I'm sure the PB Blaster had something to do with that. I sprayed about 3 coats of it on the broken stud over the course of a couple hours.
Thanks again for all the help guys. I appreciate it.
Re: Oops!! Broken Exaust Stud [Re: mopowers] #1438201
05/18/13 08:13 PM
05/18/13 08:13 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
Attaboy, Luther!
I had no doubt it would work.
Re: Oops!! Broken Exaust Stud [Re: mopowers] #1438202
05/18/13 08:27 PM
05/18/13 08:27 PM
Good job!!!
Re: Oops!! Broken Exaust Stud [Re: Pacnorthcuda] #1438203
05/18/13 08:38 PM
05/18/13 08:38 PM
New State
kidmopar Offline
kidmopar  Offline
New State
Re: Oops!! Broken Exaust Stud [Re: kidmopar] #1438204
05/18/13 09:09 PM
05/18/13 09:09 PM
McGregor,Iowa 52157
McGregor,Iowa 52157
Good Job Again!!!
Re: Oops!! Broken Exaust Stud [Re: 500ciDuster] #1438205
05/19/13 12:10 AM
05/19/13 12:10 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Awesome!! Maybe what I see as borderline to deep isn't a problem...
Re: Oops!! Broken Exaust Stud [Re: 1_WILD_RT] #1438206
05/19/13 09:39 PM
05/19/13 09:39 PM
Tracy, New Brunswick, Canada
magnumcharger Offline
There ya go!!!!
No drilling involved and another satisfied customer!!!
