Re: 68 trunk issue and moldings removal
[Re: MrHemi]
#1437875
05/17/13 07:30 AM
05/17/13 07:30 AM
Posts: 532 Marion, Ohio USA
kab69440
Marion, Ohio USA
Remove the rear seat and crawl into the trunk with a screwdriver. Pry the retainer off the lock cylinder and push it out. Insert the screwdriver into the release slot and turn it counter-clockwise. What mouldings do you need help with?
Just because you're paranoid, it doesn't mean they are not out to get you.
WANT TO BUY- Looking for a CD by 'The Sub-Mersians' entitled "Raw Love Songs From my Garage To Your Bedroom". Also, any of the various surf-revival compilation albums this band has contributed to.
[Re: MrHemi]
#1437877
05/17/13 10:28 PM
05/17/13 10:28 PM
kab69440
Marion, Ohio USA
The drip rail mouldings are held on only by tension. Pad a small pair of ChannelLocks with leather and work the corners above the vent windows off. Work slowly from one end to the other on the A pillar and side rails.
The backlight mouldings need a flat mushroom shaped release tool. Push it straight up under the moulding and work it back and forth to find the clips. I start with the too left corner.When you snag a clip, rock the tool toward a right angle and the the trim will pop as it releases from each individual clip.
