Correct paint for factory radiator #1437535
05/16/13 05:44 PM
05/16/13 05:44 PM
6T4 Polara Offline OP
Radiator was recore years ago and paint is flaking off.
What is the correct paint to use gloss, semi gloss.
Should I use a high temp. Will be using a spray bomb.
Re: Correct paint for factory radiator [Re: 6T4 Polara] #1437536
05/16/13 05:51 PM
05/16/13 05:51 PM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
I just used a primer, and a semi-gloss. Much like the air cleaner I'm doing now. Did it years ago, and still looks great. Rad. doesn't really get that hot to worry about a hi-temp paint.
