Spray bombs - the truth ...
#1437414
05/16/13 12:46 PM
05/16/13 12:46 PM
Posts: 756 North Florida
RebelDart
super street
super street
North Florida
So .... wiper motors, radiator,power steering pumps, pulley wheels, steering knuckles and control arms, etc., etc. ... we don't use spray bombs of any kind, primer or enamels , laquers or epoxies, ever ? Even Eastwoods chassis paints (not any better than Rustoleum or Krylon ?) Just seems to be alot of trouble to epoxy prime and single stage these smaller items - is it done more often than not ? back in the day I used spray paints quite a bit for these type items - what's the straight dope (not a daily driver) ? There's alot of spray paints out there for restoration (cast finish, aluminum finish, wrinkle finish), but so many pros "say no to spray bombs".
Re: Spray bombs - the truth ...
[Re: RebelDart]
#1437416
05/16/13 01:24 PM
05/16/13 01:24 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
I disagree..
I have used Eastwood's extreme chassis black numerous times, and it is more durable than any krylon/rustoleum stuff I have ever seen. Once it's cured, it is as hard as a rock.
[Re: OzHemi]
#1437417
05/16/13 01:26 PM
05/16/13 01:26 PM
Challenger 1
Cincinnati, Ohio
I disagree..
I think he was asking?
And I agree, Eastwoods chassis black is some of the best "spray bomb" stuff I have ever used.
[Re: Challenger 1]
#1437419
05/16/13 01:35 PM
05/16/13 01:35 PM
OzHemi
Garden Grove, CA
I disagree..
I understand he might have been asking, but ment I disagreed with the statement in general.
And I've had good luck with a few other various spray can paint. I think alot has to do with prep and the way you put the paint on. Plus going with better quality stuff. I wouldn't expect the 99 cent cans from home depot to hold up all that well. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: RebelDart]
#1437421
05/16/13 02:14 PM
05/16/13 02:14 PM
Posts: 2,636 Nashville, TN
MOPARMIKE69
Nashville, TN
With a gun and mixed paint you can put alot more paint on the piece with less over spray and if you use 2 part, the paint is way harder than anything you can get in a spray can.
With that being said if you use good quality paint, good prep, at least 4 coats, on most stuff it will be fine. Spray bomb paint has come a long way from the olden days in quality and longevity.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: MOPARMIKE69]
#1437422
05/16/13 02:21 PM
05/16/13 02:21 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
It's a lot less time consuming to use a spray can. I can get out the gun and spray anything, but the time it takes adds up if you do it for everything. I got a small part to paint, I'm using a spray can if possible.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: dOc …]
#1437424
05/16/13 02:38 PM
05/16/13 02:38 PM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
If your going to do much driving, it won't matter in a couple of years anyway. They all get dirty, and who wants to crawl around under there and clean?
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
[Re: rattler]
#1437425
05/16/13 03:26 PM
05/16/13 03:26 PM
Posts: 5,912 Athens, Greece
Pyper70
Athens, Greece
When you want it done right....use a spray gun....I used it yesterday and today to paint ONE item. A bracket to hold up a motion control camera...the size of two soda can stacked on top of one another.. Total time painting...20 minutes....total time cleaning my gun and area....30 minutes.
If you want a killer paint job, there are some spray cans that actually have an ampule inside the can that releases catalyst once triggered (there is a push button on the underside of the can)..You get quality paint like PPG out of a nozzle...Not cheap but I have a few cans myself in the basement where its nice and cool. Once you crack it open though, you have to use it all or you have to toss it.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Pyper70]
#1437426
05/16/13 04:25 PM
05/16/13 04:25 PM
Posts: 8,917 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I would say it all depends on the "job" as well as the exposure the parts will see. It just isn't feasible for the average guy to go and buy a 1/2 pint of every color or finish to do a car. However, if its a "custom" job where say, chassis, underside and all components are the same color then it makes sense to buy a quart and spray.
I epoxy primed and sprayed all my suspension components, engine, tranny, etc. but I used spray bombs to do my seat frames.
[Re: QuickDodge]
#1437429
05/17/13 12:26 AM
05/17/13 12:26 AM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
I use duplicolor engine enamel on everything. from pulleys, to suspension parts, pedal assemblies, bell housings. seems to work okay. 2 coats of primer, 2 coats of paint. dries fast. done.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
[Re: mopardude318]
#1437430
05/17/13 01:25 AM
05/17/13 01:25 AM
Posts: 391 Kentucky USA
RR6BBL1969
Kentucky USA
I have used Duplicolor and gotten excellent results. I believe it is one of the best spray bombs as well as Eastwood.
[Re: gtx6970]
#1437433
05/17/13 09:50 PM
05/17/13 09:50 PM
Posts: 10,766 North Dakota
6PakBee
North Dakota
I painted the exterior of an '85 Daytona with Tempo gloss black spray bombs.
