Jeep 4.0 #1437193
05/15/13 11:25 PM
05/15/13 11:25 PM
SD
Z
zrxkawboy Offline OP
Z
SD
I have a '98 Cherokee with 181k miles. I bought it last summer to use as a winter beater, but last fall, the #6 piston broke (found a couple pieces of the skirt in the oil pan). It sat all winter, as my garage is unheated. Now I need to decide what to do with it. My options seem to be: 1. pull the head and replace the piston, 2. do a full rebuild, or 3. find a good used engine.
I was originally going to rebuild, but honestly, I'm starting to lean toward option 1. I'm not normally one to take the cheap-n-dirty way out, but I'm considering it here because: the Jeep is in decent shape, but certainly not perfect; only using it in the winter, I won't put on a lot of miles; I don't own an engine hoist, though could probably borrow one; and of course, less $!
I've rebuilt engines before, but never just replaced a piston in the vehicle like this. Any thoughts are appreciated!
It's Swifty! Swifty, you toad sucker!
Re: Jeep 4.0 [Re: zrxkawboy] #1437194
05/15/13 11:57 PM
05/15/13 11:57 PM
N
NITROUSN Offline
NITROUSN  Offline
N
If you rebuilt engines before there is nothing different working on this engine. Pull the head and see what the cylinder looks like.
Re: Jeep 4.0 [Re: NITROUSN] #1437195
05/16/13 12:16 AM
05/16/13 12:16 AM
SD
Z
Z
SD
I just meant if anyone has done something similar, how did it turn out, and would you recommend going this route? From what I could see from the pan, with the piston at TDC, the cyl looked fine.
Re: Jeep 4.0 [Re: zrxkawboy] #1437196
05/16/13 08:39 AM
05/16/13 08:39 AM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
Slap a piston in and be done with it. no sence in spending tons of cash on a beater. it will be fine
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: Jeep 4.0 [Re: yella71] #1437197
05/16/13 09:14 AM
05/16/13 09:14 AM
East Texas
Mopar2DBone Offline
Mopar2DBone  Offline
East Texas
Agree with yella.. Put another piston in and keep on Jeepin... Engine probably has many years left in it..
Re: Jeep 4.0 [Re: zrxkawboy] #1437198
05/16/13 10:58 PM
05/16/13 10:58 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
And a new oil pump while you are there.
It takes gasoline to interest me.
Re: Jeep 4.0 [Re: VL21] #1437199
05/17/13 12:09 AM
05/17/13 12:09 AM
SD
Z
Z
SD
Thanks for the replies. I think I'll pull the head for a look-see and go from there.
