Re: I need an electric fuel pump!
[Re: 1969RR]
#1437128
05/15/13 11:21 PM
05/15/13 11:21 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Well most all of the inline pumps require a return regulator because they don't run an internal bypass.The Holley 12-700 is the one I have been looking into for my car with the Robmc bypass regulator. This pump looks like it would work http://www.holley.com/12-700.aspA Carter pump is a little smaller than the Holley red and they run forever Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 1969RR]
#1437134
05/16/13 02:45 PM
05/16/13 02:45 PM
Posts: 43,230 Bend,OR USA
Cab_Burge
Most electric pumps don't suck worth ahoot, they push real well My message is to mount the elctric pumps below the bottom of the tank, I use to mount my Holleys on the rear sub frame inner rail right at the bottom of the sub frame rail where it straighten out in front of the wheel well You can loosen the bracket and move the pump up and down to make it fit Make sure and retighten it after setting it up Be careful on the heat from the exhaust, sheild the pump and lines when possible
[Re: Cab_Burge]
#1437135
05/16/13 09:08 PM
05/16/13 09:08 PM
Posts: 2,138 tucson az
frank
tucson az
Have you thought about an in tank pump
How would you mount a electric in tank pump and wire it safely without buying a new purpose built tank?
Like this
[Re: frank]
#1437138
05/17/13 12:32 AM
05/17/13 12:32 AM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
what would be wrong with using a Walbro GSL 392 pump?
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
