Double adjustables Strange 6.52 stroke #1436985
05/15/13 07:14 PM
05/15/13 07:14 PM
Mi USA
Dyno Donnie Offline OP
Mi USA
Just purchased a pair of Strange DA 50007 6.52 stroke to replace my
single adj strange shocks. 4-link -110lb spring- extension now at
5 from soft on driver side -4 from soft passenger rear. Having a
compression dial will be new to me-anybody have any ideas
on where to set to start
Re: Double adjustables Strange 6.52 stroke [Re: Dyno Donnie] #1436986
05/15/13 10:16 PM
05/15/13 10:16 PM
Saskatchewan, Canada
cudabin Offline
cudabin  Offline
Totaly dependant on the amount of HP and whether it is transbrake/manual/ or foot brake. Ladder bar or 4 link. Also car weight etc...
what do you 60 foot? when I tightened mine up full i got a few 1.18 60 foots with them.
If you are not sure, I would start 3/4 tight and video the results.
Takes 2 clicks to really notice any change on those.
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: Double adjustables Strange 6.52 stroke [Re: cudabin] #1436987
05/15/13 10:37 PM
05/15/13 10:37 PM
Mi USA
Mi USA
Thanks for the input. Car is a 4-link-900 hp-sixty ft 1.28
3000lbs RR-I'll try 3/4 tight to start-transbrake yes
Re: Double adjustables Strange 6.52 stroke [Re: Dyno Donnie] #1436988
05/15/13 11:29 PM
05/15/13 11:29 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
How about some car and performance specs?
Doug
Re: Double adjustables Strange 6.52 stroke [Re: dvw] #1436989
05/15/13 11:34 PM
05/15/13 11:34 PM
cudabin Offline
cudabin  Offline
With that kind of HP 3/4 will be the place to start for sure, and watch how violent it hits the tire. then tighten the extension only 2 clicks more, and watch the difference.
You want the hit to come on smoothly and stay a while...
Have fun!
Arnie
Re: Double adjustables Strange 6.52 stroke [Re: dvw] #1436990
05/16/13 07:47 AM
05/16/13 07:47 AM
Mi USA
Mi USA
Koffel built 572 mega-blk Alston Chassis square tube engine
set back 15 " B1-BS heads-14-1 comp-SV1 Patrick Pro System
21/4 headers 750 lift torque-flt with all hard parts from cope
@ A@A Nine inch ford 4.30 15x33MT
