Page 2 of 3 1 2 3
Re: 440 Compression Test Results-Head Gasket or ??? [Re: Mr.Yuck] #1436703
05/17/13 10:37 AM
05/17/13 10:37 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Yes you could pull the head with rockers in place , but it would be a pain plus the head is going to lift off the block when the headbolts are loosened because some valves are open.
I use a coat hanger or the dipstick to hold the pushrods up on reinstall.
Re: 440 Compression Test Results-Head Gasket or ??? [Re: JohnRR] #1436704
05/17/13 10:57 AM
05/17/13 10:57 AM
Berwyn, IL
challenger70 Offline OP
Berwyn, IL
Thanks for the tips what is the best/easiest way to pop out the freeze plug in the block? Can I reuse them? Just mentally preparing my parts order. So far assuming no head/block damage I am thinking 1)head gaskets, 2)intake gasket, 3)set of freeze plugs(if I can't re-use), anything else I am overlooking? I am hoping to start teardown this weekend after the Chicagoland Mopar Connection Show.
Re: 440 Compression Test Results-Head Gasket or ??? [Re: challenger70] #1436705
05/17/13 11:02 AM
05/17/13 11:02 AM
JohnRR Offline
JohnRR  Offline
Why are you removing freeze plugs ? and no they are not reusable.
There is an NPT plug in the side of the block , in the middle and about half way up between 2 freeze plugs , this is what you remove to drain down the block , draining the radiator usually only drains it down to the bottom water pump hole.
You can take off the lower radiator hose and jack up the rear of the car as high as possible, this will drain more of the block ....
Re: 440 Compression Test Results-Head Gasket or ??? [Re: JohnRR] #1436706
05/17/13 11:06 AM
05/17/13 11:06 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
there is an NPT plug in the side of the block , in the middle and about half way up between 2 freeze plugs , this is what you remove to drain down the block , draining the radiator uaully only dranins it down to the bottom water pump hole.
You ca take off the lower radiator hose and jack up the rear of the car as high as possible, this will drain more of the block ....
what he said... you can also jack the side of the car up you are working on, but then you will need a stool or something to stand on.
Re: 440 Compression Test Results-Head Gasket or ??? [Re: Mr.Yuck] #1436707
05/17/13 11:08 AM
05/17/13 11:08 AM
Berwyn, IL
Berwyn, IL
Doh! I did not know there was a regular plug, I assumed it was a freeze plug, and we know what happens when you assume... thanks!
Re: 440 Compression Test Results-Head Gasket or ??? [Re: challenger70] #1436708
05/17/13 11:33 AM
05/17/13 11:33 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
If those plugs have never been out, they might be a b%@*&$# to get out, especially with engine in chassis.
Re: 440 Compression Test Results-Head Gasket or ??? [Re: buildanother] #1436709
05/17/13 11:38 AM
05/17/13 11:38 AM
If they're stuck break em loose with a BFH hammer rap on a breaker bar/socket rather than a steady pull
Re: 440 Compression Test Results-Head Gasket or ??? [Re: RapidRobert] #1436710
05/18/13 12:22 AM
05/18/13 12:22 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Do not take the freeze plugs out, they are not reuseable and nearly impossible to replace in the car.
the threaded plugs may or may not come out, I have never taken one out, for any reason..put a drain pan under the car and leave them in.
Re: 440 Compression Test Results-Head Gasket or ??? [Re: sthemi] #1436711
05/20/13 11:06 AM
05/20/13 11:06 AM
Berwyn, IL
Berwyn, IL
Thanks guys, I guess I need to decide if I want to go the drain plug route or the jack the back of the car up and drain route...
Re: 440 Compression Test Results-Head Gasket or ??? [Re: challenger70] #1436712
05/20/13 12:15 PM
05/20/13 12:15 PM
JohnRR Offline
JohnRR  Offline
jacking up the back of the car is less messy, when you pull the plugs they are going to spray all over the steering and K frame .Jacking up just remove the lower hose and direct it into your drain pan after you've drained the radiator.
Re: 440 Compression Test Results-Head Gasket or ??? [Re: JohnRR] #1436713
05/25/13 07:27 PM
05/25/13 07:27 PM
Berwyn, IL
Berwyn, IL
Well I made a little progress today before I had to call it quits and when I pulled the valve cover off I heard a clunk on the ground(that can't be good) and saw the headbolt between 2 and 4 was MIA and the clunk I heard on the ground. The valvetrain looks ok, the threads were a bit chewed up on the bolt but it doesn't look like it did any visable damage to anything.
Re: 440 Compression Test Results-Head Gasket or ??? [Re: challenger70] #1436714
05/25/13 07:29 PM
05/25/13 07:29 PM
Berwyn, IL
Berwyn, IL
Re: 440 Compression Test Results-Head Gasket or ??? [Re: challenger70] #1436715
05/25/13 07:33 PM
05/25/13 07:33 PM
Berwyn, IL
Berwyn, IL
Re: 440 Compression Test Results-Head Gasket or ??? [Re: challenger70] #1436716
05/25/13 08:01 PM
05/25/13 08:01 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Now you know why the gasket blew out... probably want new bolts to attach the heads..
you will probably need to at least disconnect the header from the exaust pipe, you may have to remove it entirely..
Re: 440 Compression Test Results-Head Gasket or ??? [Re: challenger70] #1436717
05/25/13 08:02 PM
05/25/13 08:02 PM
I'd bout be tempted to get a new bolt & torque it in & try it but with it bleeding compression between the 2 cyls as you originally stated I think it will have to come apart but I think I'd try it for a day just to see . Wait & see what others say. Dont forget to pull the hex block drain plug on that side as draining the rad only lowers the coolant to the level of the lower block front 1&1/8" main coolant hole on that side & it will spill coolant out of the outer deck holes which are below that level into the cyls when you pull the head
Re: 440 Compression Test Results-Head Gasket or ??? [Re: challenger70] #1436718
05/27/13 08:28 AM
05/27/13 08:28 AM
JohnRR Offline
JohnRR  Offline
The bolt looks like that because it's been bouncing around inside the valve cover with the engine running ?
just pull the head , you've run it like that for too long that there is carbon and who knows what between the 2 cylinders. you probably don't need to pull the other side after seeing the head bolt missing.
Just jack up the rear of the car and that will lower the coolant enough , water finds it's own level , physics is funny that way ...
Re: 440 Compression Test Results-Head Gasket or ??? [Re: JohnRR] #1436719
05/27/13 12:16 PM
05/27/13 12:16 PM
dogdays Offline
dogdays  Offline
You had better hope that the cylinder head did not get torched in the process. I have seen that happen it's not fun.
R.
Re: 440 Compression Test Results-Head Gasket -Update [Re: dogdays] #1436720
06/09/13 07:58 PM
06/09/13 07:58 PM
Berwyn, IL
Berwyn, IL
ok, I finally got around to pulling the head, everything looks ok head/block wise, anyway to tell for sure without the machine shop route? I do not feel any ridges/depressions with my finger nail. There was a piece of head gasket missing between cylinder 2&4. Now for the litany of questions;
1) Head gasket was part number 8519PTI(8519PT1?), I believe it's a fel-pro, is there a better alternative? I believe my engine is .030 over.
2) Should I get new headbolts? If so which ones, ARP? If not, I have a set from an early 70's RV440 I tore down, can I just swap out one of those for the knicked/marred up one? Is there somewhere I can find a matching bolt to the set I have.
3) I have a one piece valley intake gasket (one giant gasket for both sides and valley), better alternatives? Existing one has the heat crossover I'd like to block that off, any reason not too? (car just gets warmed up every now and then in Winter, rarely driven). Car has Performer RPM intake and iron heads. Is there any setups to separate the valley tray from the intake gasket?
4) I'd like to order all the parts at once to redo both sides, my mental parts list is new header collector gaskets, header gaskets, head gaskets, intake gasket, carb gasket, possibly new headbolts (if necessary). Am I missing anything? Do I need any locktite or gasket sealer? (I know the header bolts need sealant since they go through into the coolant passages).
Pics to follow...
Re: 440 Compression Test Results-Head Gasket -Update [Re: challenger70] #1436721
06/09/13 08:00 PM
06/09/13 08:00 PM
Berwyn, IL
Berwyn, IL
Re: 440 Compression Test Results-Head Gasket -Update [Re: challenger70] #1436722
06/09/13 08:04 PM
06/09/13 08:04 PM
Berwyn, IL
Berwyn, IL
Page 2 of 3 1 2 3
