Re: 440 Compression Test Results-Head Gasket -Update
[Re: dogdays]
#1436728
06/14/13 02:08 PM
06/14/13 02:08 PM
Posts: 3,358 Berwyn, IL
challenger70
Berwyn, IL
Check other posts, head bolt retorquing is not done very much at all. The location of the bolt is a problem to me, as it is in the middle which should be torqued first or second in the usual pattern.
R.
Is the "usual pattern" specified in the Factory Service Manual, or is there a better/different pattern to use?
